SOURCE: User Manual - Fossil CH2332 Wrist Watch
go to fossil.com click on customer support that is where the manuals are hope this helps
SOURCE: How to adjust the watch strap
I just bought the o-ring watch by Starck, and it looks to have the same style of strap. If you look on the side of the clasp, you will see a pin on both ends. You have to remove these retention pins first (which may require tools that are unavailable to you). First, stabilize the watch on its side on a soft mat - I used the back of a mouse pad. Then, use a thin, stiff piece of metal tool to push the pins out slightly. I used a crafting tool. Once the pin sticks out enough, you can use a fine set of pliers to pull them the rest of the way out. (If this does not make much sense at this point, you may be best off going to watch shop.) Once you remove the pins, the clasp can be removed from the strap simply by lifting the clamp. You then trim the strap with a pair of sharp scissors to the appropriate length - make sure you see exactly what the end looks like, because the shortened strap will need to have the same apperance. After trimming, reclamp the clasp onto the strap, and reinsert the pin. You may need a small hammer to get the pins seated completely. Then, you're done. So obviously intuitive, why would anyone need directions, right? Honestly, Fossil did not make this one easy at all. Kind of irritating.
SOURCE: Strap for Fossil Philippe Starck PH1035 Wrist Watch
Type in your browser FOSSIL WATCHES.
You will find numerous sites. Go thru them till you find what you're looking for.
SOURCE: ES9439 Wrist Watch: what battery doe the Fossil ES9439 Wrist Watch tak...
Link
Please visit above link for your Fossil battery requirement. Kindly contact Customer Service Team for further details.
Thank you.
SOURCE: if need new glass front??
you can go to fossil.com and they have a repair site for like thirty bucks you can pay to have any parts repaired guess thats what i will have to do to get a replacement band for my own.
