Texas Instruments TI-84 Plus Silver Edition Graphic Calculator Logo
Anonymous Posted on Jan 16, 2012
I am trying to divide a power of 10 by and another number to a neg power of 10
4,168,214 X 10^24 all divided by 74.612 X 10^-5.34 Hw do i do this?
  • Anonymous Jan 17, 2012
    That helped but I found that the real problem was I needed to put parentheses around the top and bottom portions along with the divide sign. Thanks.
k24674
Level 3:
  • Texas Instru... Master 8,093 Answers
  • Posted on Jan 17, 2012
k24674
Level 3:
Answers
8093
Questions
0
Helped
4673613
Points
21595
For integer powers of 10 you can use the EE shortcut. [2nd][,] displays E.
For non-integer values of the exponent (such as -5.34) you must use the key sequence [2nd][LOG] (10^x) then enter your negative non-integer exponent.
  • Angela Leon
    Angela Leon May 05, 2014
    I'm having the same problem... Every time I divide a number raised to 10 to the 8th power by a number raised by 10 to the negative sixth power the answer is wrong!!!!!!!!!! Everything still works when multiplying, though. D:
5 Related Answers
Anonymous
  • Posted on Feb 18, 2008
SOURCE: dividing fractions
1/3-1/8=?
Anonymous
  • Posted on Sep 10, 2008
SOURCE: fractions appear when I divide; not decimals
press 'yellow key' then press 'enter' to see answers in decimal format instead of fractions
Anonymous
  • 100 Answers
  • Posted on Jan 06, 2011
SOURCE: my textbook tells me to
Change your [MODE] setting to Degree. Press [MODE] [Down Arrow][Down Arrow] and Arrow over to highlight [Degree]. Next, press [ENTER] and, then [2nd] [QUIT] to leave the [MODE] screen.
  • 102366 Answers
  • Posted on Mar 30, 2011
SOURCE: I have a ti-30xa. How do you divide log7 by "6
7 LOG / ( 6 * 7 LOG - 2 LOG ) =
k24674
  • 8093 Answers
  • Posted on Sep 13, 2011
SOURCE: I have TI30XIIS & need
To enter a power of 10 use the key EE
For 9.1x10^(-31): type 9.1 [EE] [(-)] 31. Here [(-)] is the change sign key.
Finding averages....
add all the numbers in the selection and get a sum total
divide that sum by the number of numbers in the selection and that is the average
for example the numbers are from 1 to 10 inclusive = sum total=55
divide 55 by the number of numbers --(10) = 5.5 = average
2answers
Is 8 a prime number? And what are the factors for 20? And is 20 a prime number?
No it isn't as 1,2,4,8 can be used to divide it prime's are only dividable by 1 or itself only
20 is 1,2,4,5,10
2answers
5/6÷11/12=
5/6 divided by 11/12 is the same as 5/6 times 12/11 which is
10/11. 10 divided by 11 is___________.
2answers
How do I change a percentage to a fraction
Use this http://www.calculatorsoup.com/calculators/math/percent-to-fraction-calculator.php
OR to work it out yourself.....#
How to convert percent to fraction
  1. Divide the percent by 100 to get decimal number.
  2. Count the number of digits (d) to the right of the decimal point of the decimal number.Example: 2.56 has 2 digits to the right of the decimal point, so d=2.
  3. Calculate the factor (f) for making the decimal number an integer: f = 10 to power d
    Example:
    f = 10 power 2 = 100
  4. Multiply and divide the decimal number x by the factor f: x * f / f = y / f
    Example:
    2.56 * 100 / 100 = 256 / 100
  5. Find the greatest common divisor (gcd) of the fraction. Example:
    gcd(256,100) = 4
  6. Reduce the fraction by dividing the numerator and denominator by the gcd value: Example:
    256 / 100 = (256/4) / (100/4) = 64/25
Example One percent is equal to one hundredth:
1% = 1/100
So in order to convert percent to fraction, divide the percent by 100% and reduce the fraction.
For example 56% is equal to 56/100 with gcd=4 is equal to 14/25:
56% = 56/100 = 14/25
How to divide mixed numbers
Convert both to improper fractions, divide, then simplify.
3 3/4 is 15/4, 1 1/8 is 9/8. Dividing 15/4 by 9/8 is 120/36. Reducing to lowest terms gives 10/3, which is 3 and 1/3.
Steps to dividing 1,000,000,000 into 31536000
This is effectively the same as moving the decimal point. You are dividing by a multiple of 10, called a power of 10 (like 100 or 10000 for example).
When you divide by a number like that, you are moving the decimal to the left, by however many zeroes in the divisor (9 places in this case).
So you have started out with 31536000.0, and when you move the decimal 9 places to the left, you get
0.031536
Is it possible to have a remainder when dividing a number by powers and multiples of ten? Yes or No. Please give an example
Yes, it's possible because not all numbers are multiples of ten. For example if you divide 63 by 30 (which is multiple of 10) you get 2 and remainder 3 (because 63=2*30+3).
2answers
Jake is getting 5 cash drawers ready for the day. He takes 650 $20 bills and 725 $10 bills out of the vault. He wants to divide the money evenly between the cash drawers. How much money should he put into...
Since he has $20,250, he should put $4050 into each drawer.
To get the total amount, multiply 650 by 20 and 725 by 10, then add the two numbers together. To get the final result, divide the total by 5. Since you didn't specify the make and model of your calculator, I'm afraid I can't give you the sequence of button presses to calculate this.
2helpful
Exponent key
On the Upper right corner, below the OFF button.
Key in the number, press that YtotheX key, and input the integer. Press =. That is your answer.
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Jerry Naidoo
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
