SOURCE: error code 43 on F& P washing machine
The micro switch or the lever that activates it seems to have been the cause of the Error Code 43. Have re-seated the switch in its holder and ensured the activating (out of balance) lever is moving freely. The switch appears to be OK and now it is all re-assembled, the Error Code 43 is gone. Machine is operating normally again.
Out of Balance Switch was located below the right hand side of the computer board (module).
Rgdz John T
SOURCE: the washeer machine give a error code E4
A code of E4 means that there is to much suds or the pump is blocked. use less detergent and get detergent with he in the title. turn to off and try to restart the drain to correct problem.
You will find the code in the manual. If you do not have let me know I will send you one here.
Good Luck And Please Rate FixYa!
SOURCE: My washing machine is SANYO ASW-90WRTP. showes E4
Check on the machine there is a schamatic and it has error codes on it. it may be on the in side panel.
Testimonial: "cool thanks for that just empty the tub then will check for skidmatics"
SOURCE: i have a stirling washing machine xqb90-701clps
my machines not washing properly i think.. The wash is complete but theres still powder on the clothes.. What do i do to solve it?????
SOURCE: The washing machine wont stop
If that is a whirlpool as you do not have a brand or mod # that would most likely be a flow sensor. It is located under the top cover. remove screws top rear remove cover on top of machine. you will see that device in the tubing located just after the water inlet valve it will be white round device and most likely will have to small blue wires going to it.That is a somewhat pricey little part like 100.00 last time I got one but with whirlpool who knows could be more or less now. On that note might be cheaper to have the unit looked at by a pro. If you remove the lower kick panal you should find the tech sheet that will tell you what the code means but I'am sure it is overflow .. If you need more help please ask....Thanks for voting good luck
