I am using a Konica Minolta Bizhup Pro C6500 and I have received the error code c-4701 multiple times. I can not figure out why and I have since called the technician to repair the problem but I would like to know what causes this error code. I do not think the technician knows either and somehow he seems to constantly over-ride the problem but then when he leaves the code reappears and I am back to square one. This has become very tiresome. Does anyone know what this code means?
- 4701 error
Communication fifo problem error 4702/4701 of 5500;6500;6501 konica minolta mfp printers
1) reseat all connectors in Ipb
2)image memery controle board
Inspite doing all these if the problem persists please reload the firm ware/flash firm ware.
Last one is to replace image memory board only .no need to replace prcb; overall status board; nvram
SOURCE: konicaminolta bizhub pro c6500
its a 24Volt error. It usually means replacing the ADU drive board. no way to cheat or disable it/
SOURCE: konica minolta bizhup 6501 error c-2452
Something with your developer causing not enough toner. Maybe an auger issue in the developer or in the toner feed itself?
SOURCE: what does code 2454 mean on the konica minolta
Developing motor for the Black, working in conjunction with Toner Control Sensor.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Konica Minolta C6500 Error Message
There is a paper somewhere in the copier. Maybe earlier you have a paper jam and one paper or just a part of the paper is still in the copier.
Most likely the paper is near the imaging unit.
SOURCE: konica minolta bizhub pro c6500 error c2452
Toner low density abnormality
When the developing motor/M (M21) is ON, the maximum detection value of TCR sensor/ M (TCRS/M) is the specified value and the difference
between the maximum detection value and the minimum detection value is over the specified value.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
