Fault code f 05
On my Hotpoint, I tried to solve this F05 issue and firstly replaced the drainpump which didn't solve the error at all. I checked and cleaned all the pipes too. Then today following a Youtube instruction, I changed my pressure switch but to my irritations, I still stand where I started.
SOURCE: Hotpoint Aquarius not completing finally spin and pumping out
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
The
filter is inside the machine. Turn off the power and pull out the machine to
get to the rear. Pull out the hose you
see going into the wall pipe, lay at floor level or plastic bag to drain out
remaining water in machine. Remove the panel at the bottom (2 screws) where the
discharge hose comes out. You should see a black concertina type tube coming
from below the drum attached by a jubilee clip. The filter is inside. Loosen
the clip and pull away the tube, take out the filter and clean it. When you
replace it don't forget to put the ball float back in (exactly as you found it)
and check it’s well fixed by running a spin cycle before sealing up. Caution, the exit drain hose shd be fitted at
the exact location where you found it, abt three feet up from ground level.
Pl
rate me nice for the free help, thnks.
SOURCE: flashing lights and error message f-05 on hotpoint
check water pump filter, it may be blocked or jammed
SOURCE: Hotpoint Aquarius WT740 Fault Code
Hi. F05 means pressure switch jammed on full.
Check pump for blockage and that it is working, if no joy you will have to call an engineer
SOURCE: hotpoint ultima washing machine showing fault code
Error code F05 indicates pressure switch jammed on full.
Remove lower rear panel of washer.
Remove large black hose on bottom of drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
Make sure there is no water in drum before you start.
Please rate my solution.
Thankyou.
SOURCE: fault code stopping washer from working
My washing machine will not spin and in fact turn around at all, i did a wash earlier and it was making a funny noise...like some thing was caught in the drum. It is about 3 years old....It does still fill with water thou!
