Samsung HL-S5086W 50" HDTV Logo
Tim Potter Posted on Dec 26, 2011
Samsung HL-S5086W 50-Inch DLP HDTV keeps turning off for no reason
David Hall
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Jan 15, 2012
David Hall
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
0
Helped
2933
Points
5
After turning off do the LEDs on the front panel blink on and off?
If so, you may have an issue with the lamp. Probably needs replaced or repaired.
1 Related Answer
Anonymous
  • 70 Answers
  • Posted on Jul 08, 2008
SOURCE: We have a Samsung HL-S5086W
sound demodulator board, is a common fault with this model.
remove plug in board and send it to samsung for exchange.
cost is around 223 australian dollars.
other than that you could opt to run the sound via an external sound system.
1helpful
HL-S5086W turns itself off
if your tv is dlp. the blub is probably the cause. i have a r5087 and had same problem. replaced blub and set works fine
Dlp chip for samsung
buy a light engine as the chip alone is over 200 or replace the set.
I have a 50" samsung
Check the Fans make sure they are not dirty ,if they are clean them,Fan2 error means something is wrong with Fan2#
It started out with 2 burnt pixels and then more and more were burning out. Now after 2 weeks I have about 1000 burnt on my samsung DLP HL-S6186W. Is there anything I can do?
Burned pixels or stuck pixels? Check out this website http://www.jscreenfix.com/basic.php it will help you, but if you got too many I wou;d be looking at a warrentee issuue,
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Display is to high on dlp set
the entire light engine assembly is not positioned in far enough. did you replace the color wheel yourself ?. if not call the tv repairman back to reposition
We have a Samsung HL-S5086W 50-Inch DLP HDTV. Works fine one min. come home few hours later no one has touched it... and now the sound doesnt work. Any ideas to what the problem might be?
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
