Texas Instruments TI-89 Calculator Logo
Posted on Oct 02, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Inequality My TI89 does not solve the inequality (3x + 1)/x < 0. However several students of mine can. How is this possible?
Stevan Milanovic
Level 2:
Sergeant:
  • Texas Instru... Expert 267 Answers
  • Posted on Sep 18, 2016
Stevan Milanovic
Level 2:
Sergeant:
Answers
267
Questions
Helped
221783
Points
795
You can see images below
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Oct 17, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
862
Points
You need to input the equation, (3x+1)/x<0, then you need to indicate that you are solving for x by putting comma then x. The equation you are inputting should look like this: solve((3x+1)/x<0,x) and the answer will be -1/3<x<0. That ",x" is telling the calculator to solve for x.
How to solve x3-3x2-4x through this fx-82MS calculator?? pls rply as soon as possible..
There is nothing to solve because you do not have an equation, nor an inequation (inequality). You need an equal sign, >,<, etc.
All you can do with this polynomial is try to factor it. Here is the factored out form
x^3-3x^2-4x=x(x^2-3x-4)=x(x-4)(x+1)
To factor (x^2-3x-4) look for the divisors of -4 whose sum is -3
You cannot do that on your calculator because is does not have a Computer Algebra System or CAS.
2answers
How do you solve for an inequality with an absolute value using functions on calculator? (example |x-1|<9
Sorry, the calculator cannot solve such ualities (nothing to do with the absolute function).
To find the solution set you need to study the two cases for the absolute value.
Case 1
If x-1> 0, the absolute value is x-1. The inequality takes the form x-1<9. You can solve it as x<10
Case 2
If x-1<0, then the absolute value is 1-x. The inequality becomes 1-x<9. The solution for this inequality is x>-8
Combine the two domains to find the intersection
-8<x<10
2helpful
Solve the two sided inequality and show the solution on real line 7 < 1-2x &#8804; 10
7 < 1-2x ? 10
7helpful
7 < 1-2x ≤ 10
7x-2y=1 y=3x
And your question is? If you just want to know how to solve this system, you only need to substitute one equation into the other and solve for the remaining unknown.
y=3x (equation 2), so plug it into equation 1
7x-2y=1
7x-2(3x)=1
7x-6x=1
x=1
from equation 2 then, you know y=3x=3
Using the ti89 to solve mesh equations
This book is what I used to help learn how to solve mesh circuits. A high education level helps. You just set it up as you see it in a simultaneous equation.
Electrical Engineering Applications with the TI-89
Electrical Engineering students will find the 70 topics covered in this book provide in-depth analyses of how to solve many common engineering problems using the powerful CAS system of the TI-89.
Author(s) - David R. Voltmer and Mark A. Yoder
[email protected]
2answers
3x + y = 0
The possible solutions are
x= -y/3
y= -3x/1
1helpful
2answers
How to use ti 89 with a problem like "-(3x+1)-(4x-7)=4-(3x+2)'
Just plug in one side of the equation and find the answer. Then plug in the other side and compare answers.
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Jerry Naidoo
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
