Home Fencing Logo
donald partlow Posted on Dec 11, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can I download a free copy of a wayne dalton wizard garage door opener owners manual and instruction manual ?
pawnpower
Level 3:
Master:
  • Master 851 Answers
  • Posted on Oct 19, 2018
 pawnpower
Master
Level 3:
Master:
Answers
851
Questions
Helped
247161
Points
2332
5 Related Answers
A
Anonymous
  • Posted on May 26, 2008
SOURCE: Garage Door issue
http://www.wayne-dalton.com/Files/ProductManuals/Residential_Garage_Door_Openers/DoorMaster/300640%20P4%207-9-2007.pdf
geemarie
Gayle Ashbach
  • 876 Answers
  • Posted on Aug 01, 2008
SOURCE: craftsman garage door opener instruction manual
Have you tried the manufacturers site at either craftsman or sears. You should be able to find it there. You will need your model #.
Anonymous
  • 4 Answers
  • Posted on Jan 15, 2009
SOURCE: wayne dalton garage door is humming but wont open
Likely the plastic gears are worn out. Unplug the unit from power source, remove the cover, look at the gears. If worn, it will be obvious from the shavings from the gears. You can buy the gear kit on EBAY for a little as $20 depending on the manufacturer and model. Before removing the chain drive, lock a pair of vice grips on the chain and metal chain rail to keep the chain from turning from its current position. The gears can be replaced without removing the opener. Even if you have to remove the opener, it is a simple task. Most have four bolts that need to be removed and it will be in you hands.
Anonymous
  • Posted on Jan 16, 2009
SOURCE: My Wayne Dalton garage door will open with remote but not close
your infrared sensor is either misaligned, faulty, or you have a broken wire from your sensor to your door opener. (Flashing light indicates infrared light path is broken). both sensors should indicate green led. door wil not come down is safty feature to prevent door from closing when light path is broken.
Anonymous
  • Posted on Aug 09, 2009
SOURCE: wayne dalton classic drive 3018, door goes 90%
wayne dalton classic drive squeaks and binds then stops
How do i reporgram a wayne dalton keypad
I would look into buying a liftmaster jack shaft its a much better unit but to get u buy just press the little red button on the opener type in your code
1helpful
Batteries need changing in the garage door remote control. It requires the code to be reset but the previous owners of the house left no information. It is a Wayne Dalton, Magic Touch, Model Number...
Using a step stool reah up and remove the plastic light cover from the garage door opener and the the code setting instructions are written on its panel. Or seach on LiftMaster.com for help.
2answers
Need instruction manual for Wayne Dalton Chamberlin WD 220 grage door opener
The LiftMaster or Chamberlain web site has instruction manual downloads for all the models.
Don't have instructions for my wayne dalton door need spring instructions
Wayne- Dalton uses 4 different types of counter balance springs-extension, torsion, torquemaster 1, and torquemaster 2. I would need this information for a good answer. A photo would help a lot too. Thanks BB
Can i use the ''clicker'' model CLT1 with wayne dalton quantam 3316
It is compatible with Wayne Dalton opener manufactured between 1983 and 1987.
How to have security with a lost wayne dalton garage door remote
Go to this site and follow the instructions.
http://www.1stdooropeners.com/299264coding.htm
I have a wayne dalton garage door opener and the light stop working after and over ride or over use I let the motor rest and work again but the light stop working I replace the light bulb and nothing...
Try unplugging the unit for ten seconds.If that dont do anything youre have to call wayne dalton they should warranty the light socket replacement ,super easy to change out.
Top Stanley Home Fencing Experts
ADMIN Andrew
ADMIN Andrew
ADEL AUTO DOORS
ADEL AUTO DOORS
Level 1 Expert
Yarik Bess
Yarik Bess
Are you a Stanley Home Fencing Expert? Answer questions, earn points and help others
