WE ARE WINE COOLER MANUFACTROR IN CHINA , OEM FOR KELONG,COORPERATE WITH HUSKY/COCACOLA/MGB ETC. WE KNOW CDA FOR QUITE A LONG TIME , BUT DID NOT KNOW THE GUY WHO IS IN CHARGE OF SUPPLY AND PURCHASING , IS THERE ANYONE WHO CAN HELP ME ? BETTER ADVICE EMAIL ,TELEPHONE , NAME ETC~ ~ THANKS A LOT ~ ~
SOURCE: Wine cooler gets too cold (freezes)
Check your thermostat setting, if the setting is ok then something wrong with your thermostat control.
SOURCE: My Koolspace cooler in my VK250 wine fridge quit cooling
I have the same problem with mine and have tried the same things as you have. I took my unit to a air conditioner service place and they said these units are not worth fixing. It would cost about $150 to add a valve so they refill the gas and then try to find out why it is leaking. I am about to order another one which makes me vary mad. My unit is 1.5 years old.
SOURCE: Haier Wine Cooler
Hi LinnieMcAdam,
I'm Harvey the Master Plumber.
Your question is: Where can you find a 10 Watt replacement light bulb for your Haier Wine Cooler?
I usually have success at the hardware store. Start there. Then you can try the store where you bought it or call Haier.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
SOURCE: Cuisinart Wine Cooler
If you call (Cuisinart’s service center (800) 726-0190), they will send you a brand new unit for $10.00.
Happy Holidays,
AC Freeborn
SOURCE: E4 Code
Between phone calls to danby and my neighbor, we fixed this problem. My E4 was on the left (lower chamber). If you have one on the right it is the upper chamber. The E4 is a defrost sensor that can be ordered from Danby's distributor (call Danby for the one in your area). The part and shipping were around $30.
If your E4 is on the left...
- remove the top shelves
- open the cover inside the cooler above the digital read outs (the top unscrews)
- inside is were the repacement sensor plugs in
- replace the one with the long cord
- run the sensor down the back to the lower chamber
- replace all covers and parts
If the E4 is on the right...
- look on the right hand wall for a black plastic grate, the sensor is under this grate
- replace the sensor (simple plug and play)
- replace the racks.
Please pass this on, it was a ***** to deal with Danby and I nearly trashed the cooler out of sheer frustration.
