Computers & Internet Logo
Z. Zeno Posted on Nov 26, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i find a key for my linksys router?
Model No. WRT54G2V1
gdcroft
Level 2:
  • Expert 192 Answers
  • Posted on Nov 27, 2011
gdcroft
Expert
Level 2:
Answers
192
Questions
Helped
90585
Points
664
Try the following procedure on a computer that's directly connected to one of the router ports with an ethernet cable. This procedure will not work if you're connected wirelessly. Open a web browser, such as Internet Explorer, and type in http:192.168.1.1. A window should pop up asking for a user name and a password. Don't enter a user name and type admin for the password. Hit ok. The router setup screen should come up. Click on the Wireless tab and then the Wireless Security sub-tab. You should be able to see your present wireless network security key on this screen. You can also use this screen to change the key if you want.
If you want to make some changes first select the security mode you want to use.
I believe WPA gives better security but I've had some trouble using it on older computers. I use WEP. I've been able to get this encryption scheme to work with all of my computers. Next select the type of encryption. I like 128 bit 26 hex digits. Next enter a pass phrase and hit generate. The pass phrase is like a password. It should now generate four 26 character keys made up of various letters and numbers. Write down the first key and make sure you've checked the 1 box for default transmit key. Save your setting and exit. You wireless network is now secure. If you try to connect to it using a wireless device you will be prompted for a security key. Depending on the operating system you're running, you may just be able to enter the pass phrase or you may need to enter the 26 character key you wrote down. You should only have to do this once for each of your wireless devices. After the first time they connect to the secured network they should automatically remember the security code. I hope this advice helps you out.
Sync wrt54g2v1 router to modem?
Turn off the modem (i am assuming you are using a cable modem. if it is a DSL modem, this will not work) and the router. Turn the modem back on and wait until all the LED's on the front of the modem come on and blink or stay solid, then turn the router on. If it is DSL, you will have to refer to this page:
http://support.linksys.com/en-us/support/routers/WRT160N
3answers
How to set up router with a lap top
well you will have to setup the router to run on ethernet, perform a mac clone for your cable modem then setup the wireless.
1helpful
Is WRT54G2V1 compatible with windows 7?
Nearly all new wireless routers are compatible. There is no installation required. They use a web interface to administrate.
Linksys WRT54G2
Login via web browser.
192.168.1.1
User: (none / blank)
Password: admin
Lost login credentials? Hold the reset button in the back till it reboots. This clears all custom settings.
1. Check the firmware version. http://homekb.cisco.com/Cisco2/ukp.aspx?vw=1&articleid=4046.
2. Download firmware upgrade file. You must choose based on version on step 1.
http://homesupport.cisco.com/en-us/support/routers/WRT54G2
3. Install
http://homekb.cisco.com/Cisco2/ukp.aspx?pid=80&vw=1&articleid=4030
I hope it clear and the links work. GL!
What is the default password for the wrt54g2v1 wireless router
Hi Jacob
When you go to Linksys for setup,try Admin,or admin,as user name and leave the password blank.Those are usually the defaults.
If this works for you,please rate my post?
Bob
PS they're at 192.168.1.1
I have linkys wireless router model wrt54g2v1.after i back up my computer i lost the linkys file. i cannot find cd for installation. now i am unable to open internet.
mpshyla
The reason for the CD is to configure the router to your cable modem. So if you reinstalled your computer you do not need the CD again. All you need to do is set the computer's Gateway back to your router. The links below will help you do this.
http://www.fixya.com/support/r4602477-check_change_computer_ip_address_in
Let me know if you have any more problems or questions.
Issken
http://www.fixya.com/users/issken
3answers
Forgot my passwork so what do i do to a wrt54g2v1 routor
At the rear is a small hole in that hole is a button, the reset button, press this for a few seconds with the power removed, and it will revert to Factory settings...Now you will have to re-set it up all again. The link below will allow you to download a PDF Adobe reader, format, manual. pdfdatabase.com/wrt54g2-v1-manual.html
Have a linksy t-mobile router wrtu5g-tm and a linsky wrt54g2v1 how do hook these up for a wireless compter
First if this is a new router or not more than a year, better contact your router manufacturer and have them configure it for you.
Trouble accessing router, in terms of the password
default is:
Username: "leave it blank"
Password: admin
All else fails there is a reset button on the back you push with a paper clip end for about 8 seconds. You'll then need to access and re configure for your use.
1helpful
How can i reset my Linksys Wireless-G2.4GHZ Broadband Router settings
Try to reset the router. This should resolve your problem. That model has a small hole were you must press with some a paper clip for exemple for a few seconds. This will reset the router to its original state.
Top Linksys Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
