I have un-installed and then re-installed printer driver but to no avail. Do I dump the printer and buy a new one?
SOURCE: CLP-510 SPL-C Error message
SPL stands for "Samsung Printer Language". You are using an USB cable that is either too long (above 6 ft.) or too thin (cheap cables).
The reason why the test page prints is because it is a very simple and small page (thinking on kbyte terms). But larger streams of data do not arrive correctly due to attenuation and the error page prints instead.
If it is absolutely necessary to connect beyong 6 ft, you need either a good quality USB cable (try the Belkin brand found at OfficeMax), or connect using a parallel cable.
SOURCE: spl-c error-including corrupted data BEWARE SPAM NUMBER +1-800-532-4187 BELOW
I should have updated this a while ago, as I see others have had the same problem since my post on 27 August.
After calling Samsung technician out to take a look, he suggested getting a higher quality cable (conected to the computer). Despite the fact that the cable which we'd been using for months always seemed to work ok, we got another one of higher quality, and the printer now works fine.
I don't know why the cable stopped working efficiently, but it did.
I hope this helps...
SOURCE: toner empty error
toner empty replace toner with without reset chip
i want window file printer start without reset chip run printer
i am all ready use ml1640,ml2245 printer file use
thanks
vijay
SOURCE: Ricoh printer printing error: undefined offending command: mz
it is a logic card problem. so pls checked it from service center.
SOURCE: I have in my windows 7 installed laptop a samsung ML-1610 Printer
TRY IN WINDOW XP
Testimonial: "rank: Master... Any more commemnts? :) Fast and reliable."
