U LINE wine cooler model ULN-75 WCSS-00
SOURCE: Uline wine cooler 9 years old, model ULN-15VWC-00.
the odds are your door gasket is leaking.
Good Luck,
Gilsh
SOURCE: Wine cooler #ULN-75BWC-00 motor seems to have shut
the motor could be defective or it could be low o refrigerant causing the pressure switch to not kick on the fan. Could even be wires have come loose from the fan. If the fan does not work it won't cool. however it mould most likely cosy you more to fix if you take it to a shop to have it repaired if you have the tools to test it with I can help you so let me know if you have a test meter volt ohm meter and I can tell you how to test the system.
SOURCE: How do I access and
Most
likely the Thermostat is bad not bringing the unit back on; the
Thermostat is the temperature control knob located in the toe grille of
the unit.
Removing toe grille you will see a little box that houses the
t-stat. If you wanted to test to be sure just remove the 2 wires that
are connected to the thermostat and conncet them together to make sure
compressor and fans start up.
Hope helps.
SOURCE: MY COLD CONTROL IS BAD
go to googlr type your refrigerator brand name and parts .
if you would not get. see me e-mail [email protected]
i need brand name and model #
