E4 Code
Between phone calls to danby and my neighbor, we fixed this problem. My E4 was on the left (lower chamber). If you have one on the right it is the upper chamber. The E4 is a defrost sensor that can be ordered from Danby's distributor (call Danby for the one in your area). The part and shipping were around $30.
If your E4 is on the left...
- remove the top shelves
- open the cover inside the cooler above the digital read outs (the top unscrews)
- inside is were the repacement sensor plugs in
- replace the one with the long cord
- run the sensor down the back to the lower chamber
- replace all covers and parts
If the E4 is on the right...
- look on the right hand wall for a black plastic grate, the sensor is under this grate
- replace the sensor (simple plug and play)
- replace the racks.
Please pass this on, it was a ***** to deal with Danby and I nearly trashed the cooler out of sheer frustration.
I have the same code. 5 minute reset did not work
Same problem, different brand: Frigidaire FJG0505SD. Wine cooler is heating ! Up to 28 degreees Celcius. Reset does not work. From the solution given I still do not understand what the error code E4 means...
Hi: I also have the E4 alert. I also have done the 5 minute reset, but that did not work. What should I do next.
Sally [email protected]
thank you
