Question about Texas Instruments TI-84 Plus Silver Edition Graphic Calculator
My 'X=" isn't showing up above the "Y="
My 'X=" isn't showing up above the "Y=" after I push the Y= button.
  • Texas Instru... Master
  • 8,081 Answers
When you push the button [Y=] to open the function editor you will see Y1=,Y2= etc. That is the default behavior. By default the graph type is FUNCTION (y=f((x). However there are other graph types, for instance PARAM, POLAR, and SEQUENCE.
For Parametric graphs, you need two functions x as a function of t and y as a function of t. In this case, when you open the function editor, you will see pairs of functions x1(t), y1(t), x2(t), y2(t), etc. Both x and y functions of the pair must be supplied.
So if your x= function is not showing, then you must open the MODE screen, and scroll down to reach the 4th line that says FUNC, PAR, POL, SEQ. Highlight PAR and press ENTER. You do that only if you want to graph parametric functions.
Posted on Dec 18, 2011
SOURCE:
Kenmore Dishwasher locked up
Sounds like the washer CPU is defective, have it diagnosed by a local repair technician.
Jul 28, 2017 | Dishwashers
Radio in 2003 GMC Yukon isn't working
Even though it doesn't say locked, it probably is. Check your driver's manual to see how to reset it.
Jun 30, 2017 | 2003 GMC Yukon
My monster power outlet isn't giving me power, the
there is probably a reset button some where make sure that its pushed in good. sometimes if you dont push on it good you'll only reset one side only and all outlets work in pairs hot will not work without the nuetral. i hope this helps
If you need further help, I’m available over the phone at https://www.6ya.com/expert/robert_e9d0abd7cc2508b3
Jan 25, 2013 | Audio Players & Recorders
My psp down arrow button not working... how can i fix it?
The only way is to take it appart and realign the pieces. There isn't a whole lot to them but they have a bezel that is rubbery that pops in and out when the button above it is pushed. This contacts the board under it and sends the signal for the button you pushed. It seems as if the rubbery bezel part under the button is not popping back out so it won't allow you to register a button push. It's not too hard, just take your time, don't force anything, and be patient as these things fit together very tightly and can be broken if forced.
Sep 28, 2012 | Sony PlayStation Portable (PSP) Slim...
My Power Acoustik PTID-7350NRBT angle feature isn't working
If you're still looking for help I have the same one and had the same issue. You have to push the eject button once and right after push and hold it and it will let you change the angle. You have to be really quick between the push and push and hold. If it opens, just close and try again.
Jun 29, 2012 | Power Acoustik PTID-7350NRBT 7 in. Car DVD...
When I push the letter "G" , for example, a
If the printwheel isn't distorted or you aren't in KBII or a language mode the printwheel homing pawl is likely broken. You need a tech.
DickyO
Sep 01, 2011 | Brother GX-6750 Typewriter
Hi - the CD tray cannot open. It is empty - no CDs in there. I hear a buzz, but an "error" message comes on. I tried pushing on the tray while turning on; I unplgged the CD player, I put it on...
The loading tray belt has more than likely stretched or snapped.
The buzzing you hear will be the motor spinning freely.
The 'ERROR' message will show up because the tray isn't opening
and activating the 'tray open' switch, therefore the 'tray closed' switch
is permanently activated after the 'open/close button is pressed.
Aug 20, 2011 | Marantz CC-4300 5-Disc CD Changer
We are currently running Comcast internet and phone through a Netgear Wireless-N 300 Router and an Arris TM502G Modem. Our phone service works fine, but the "Link" light isn't showing up for...
There's a reset button on the back of the modem. It'll power cycle it. That should work and if it doesn't make sure everything is connected and tightened.
Jul 29, 2011 | Arris Touchstone 450a (CM450) Modem
I've had my acer aspire 5741z for about four
I think the problem is your battery pack..or to make sure contact a reliable and skilled computer technician handling the trouble personally is much better to make sure it will be fixed in no time..
Jul 05, 2011 | Acer Computers & Internet
Fan Blows, heater works, NO light on "A/C" Power
Yeah, before you do that, check all your fuses first to make sure there isn't a blown fuse. If all ok then it's time to start looking into the ac control panel. Some panels can be disassembled and a little cleaning can get them working again, just takes a little time, better that $300 to $500 for a new one.
Jun 28, 2011 | 1999 GMC Yukon
Texas Instruments TI-84 Plus Silver Edition Graphic Calculator Logo
144 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Steve Allison
Steve Allison
Ekse
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
