Air Conditioning and Heat for Volvo XC70 Logo
EUGENE SALERNO Posted on Oct 29, 2011
Hvac blower will not shut off and will kill the batt
  • EUGENE SALERNO Jun 09, 2014
    I FIXED IT IT WAS THE CONTROL MOD
tom_w64138
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 17 Answers
  • Posted on Oct 14, 2019
tom_w64138
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
17
Questions
Helped
3735
Points
34
Until you get problem fixed . you could install a knife switch by taking off battery wire to your battery, then install the switch between wire and battery, this way you could switch the battery out of the car . of course you will have to remember to turn off switch when not using car , and to turn switch back on when using car.
YES this is a lot of trouble using this tempoary fix. BUT it will let you use your car until fixed. it sounds like you have a short? auto parts stores should carry this switch. OR YOU COULD PULL THE FUSE FOR THE BLOWER . SO IT WILL NOT RUN BATTERY DOWN. the relay for the blower could be shorted out? the switch for the blower could be shorted out? putting the switch in is easier than disconecting the battery cable each time. NOT A FIX , just something to get you by until you get it Fixed. good luck.
99 Cadillac DeVille HVAC blower won't shut off kill battery
https://www.autogenius.info/cadillac-deville-1999-fuse-box-diagram/#:~:text=Cadillac%20DeVille%20%281999%29%20%E2%80%93%20fuse%20box%20diagram%20Year,block%20on%20the%20driver%E2%80%99s%20side%20of%20the%20engine.
2helpful
3answers
I have a 2009 Impala and the HVAC fan quit.
It's probably not going to be a fuse issue , you people have limited thinking because you have no clue how the electronic's work on your vehicles . The HVAC contol module as battery supplies yes , but control the blower motor with PWM - pulse width modulation controller .
Blower Motor Control Processor
The blower motor control processor is an interface between the HVAC control module and the blower motor. The blower motor speed control, battery positive voltage and ground circuits enable the control processor to operate. The HVAC control module provides a pulse width modulation (PWM) signal to the control processor in order to command the blower motor speed. The processor supplies 12 volts to the blower motor through the blower motor voltage supply circuit. The control processor uses the blower motor ground as a low side control to adjust the blower motor speed.
Most of the time the Blower Motor Control Processor is bad , without testing this is just a guess . Your best bet , take your vehicle to a qualified repair shop.
2001 Jeep Grand Cherokee blower motor won't shut off.
If you pull the top left fuse, it should kill the blower motor till you figure out the problem. I don't know if you have automatic hvac or manual?
Air/heater wont shut off
If the blower motor won't shut off, pull the blower motor relay in under hood fuse box. That should kill it till you find the problem. I don't know if you have automatic hvac or manual hvac?
Can you check for hvac trouble codes? Some of the national brand auto stores will check codes for free.
If blower motor wiring connector has both voltage and ground, it will run as long as the battery has voltage.
I saw two different wiring diagrams on your blower motor, I don't know which one applies?
2008 Impala blower don't work
You probably have a bad blower motor control module .First check the Batt. 4 fuse 30amp in the under hood fuse box .
Blower Motor Control Processor The blower motor control processor is an interface between the HVAC control module and the blower motor. The blower motor speed control, battery positive and ground circuits enable the control processor to operate. The HVAC control module provides a pulse width modulation (PWM) signal to the blower motor speed control processor in order to command the blower motor speed. The processor supplies 12 volts to the blower motor through the blower motor voltage supply circuit. The control processor uses the blower motor ground or low reference as a low side control to adjust the blower motor speed.
Where is the fuse for the heater located in a 2008 gmc sierra
Do you have The Automatic or Manual HVAC system ? Doesn't matter fuse's are the same ! Out in the under hood fuse / relay box are two fuse's for heater HVAC BATT fuse #39 10 amp an # 70 40 amp . HVAC BLWR . HVAC = heater ventilation an air conditioning ! So Tom what problem are you having ? Heater fan not working ? There is also a blower motor control module involved !
1helpful
4answers
I have a 1987 Intertherm FEH-015HA electric furnace. The issue I am having is that my blower will not shut of unless I pull the disconnect. My thermostat will operate the heating elements like normal,
You most likely have a bad fan limit / cycling switch. If you kill the power to the furnace see if you can trace the wires from the motor to where the connect to the switch. It looks like a round button with tabs sticking out of it for the wires to connect. Mark down where the wires were connected and take it to a HVAC business or furnace supply house. Be sure to have the model off the furnace with you so you can get the correct parts.
The heater fan won't stop, even if i turn off the key the fan still turn, unable to control it, it only turn at one speed (not the fastest one), i check the resistor it look like there's a short in it, the...
Your impala doesn't have a resistor , it has a blower motor control processor and it doesn't work the way you think it does
Chevy Trailblazer EXT Blower Motor Won Turn Off
The blower motor control processor is an interface between the HVAC control module and the blower motor. The blower motor speed control, battery positive voltage and ground circuits enable the control processor to operate. The HVAC control module provides a PWM signal to the control processor in order to command the blower motor speed. The processor supplies 12 volts to the blower motor through the blower motor voltage supply circuit. The control processor uses the blower motor ground as a low side control to adjust the blower motor speed.
HVAC Blower Motor Circuit
5helpful
Water was leaking inside on passengers side, now
HVAC drain tube was blocked and condensation could not drain to the outside of the vehicle
as a result the water pooled inside the HVAC case leaking on the inside and killing your blower motor and probably blower motor resistor
clear the drain, replace the blower and resistor and you'll be back in business
Top Volvo Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Paula Hamilton
Are you a Volvo Vehicle Part and Accessory Expert? Answer questions, earn points and help others
