SOURCE: need to unlock code for sony dvd
After getting clarification from Fixya I can pass the links below to you to check yourself
Some players are harder than others to do this but you may want to try here or here
Comments:
Toshiba's and JVC's are the harder ones to do
I use a Phillips myself as it is not only cheaper but has much more going for it than many of the higher end units. i throw anything at it and it just plays
The older the unit that harder it is to do the region free thing with.
I let my EX have the panasonic (big grin)
If you cant find a fix then look at the codes available for cheaper brands and how easy it is to do it before you purchase one
SOURCE: DVP NS15 DVD unlocking
i have a DVP LS500 of which i purchased from my local Sony dealer i asked for it to be region free all he done was got a one for all remote and entered a 4 digit code hey presto region free hope that helps
SOURCE: In Need of DVD code for Sony DVP-SR200P
Unfortunately the only region code your Sony will play is the one that is printed on the bottom of the unit.
SOURCE: Unlock regional code for Sony DVP-NS575P
1) Turn your DVD off. 2) Use the remote control and press:
- Display
- Top Menu
- Clear
- Power
This should power the device into Service Mode.
3) Choose option 2 and then choose option 4.
4) There should be two fields: Input Code and Current Code, each one with 5 chars long.
Type: 12450
Then push zero on all the 5 places of the first and the second field.
Push ENTER.
5) There should be a zero on the device display, meaning that all regions are free.
6) Press POWER to turn it off and you're done.
Let me know if it works!
