Lexmark X4650 InkJet Printer Logo
Anonymous Posted on Oct 19, 2011
My lexmark X4650 printer keeps giving me blurred copies. How do I fix?
  • Official Brand Answer 3,344 Answers
  • Posted on Oct 19, 2011
Anonymous
Level 0:
Answers
3344
Questions
0
Helped
923781
Points
5508
It could be that your cartridges are not aligned. Please follow the steps below to fix your problem:
  1. From the printer operator panel, press the Setup button.
  2. Go to Maintenance.
  3. Select Align Cartridges. Your printer will then print a page to align your cartridges.
  4. After the test page is printed, try to print a document again to verify that the problem is fixed.
Should you still need assistance, please leave a comment to my response and I'll get back to you. Should this resolves your problem, your rating will be greatly appreciated.
How to remove ink cartridge from lexmark x4650
You may refer to this article from the Lexmark website: How to Set Up the Lexmark X3600 or X4600 Series All-In-One. The Lexmark X4600 Series User's Guide will also give you more detailed instructions on how to remove your cartridges from your printer.
I hope this helps.
My lexmark 4650 is printing blurred copies.
My Lexmark 4650 keeps telling me that my margins need adjusting, plus it is giving me blurred copies.
Check Page Preview before printing your file and see if the application you are using recognizes the entire page and does not cut-off the edges.
You can try to print Fit to Page or Borderless and see if that helps.
For your blurred copies, Please follow the steps below to fix your problem:
I have a Lexmark X4650 and about every 2 inches the print is fuzzy/blurred. How can i fix this?
Some of the ink-jets that shoot the ink onto the paper are clogged.
Use the Lexmark software for the printer to run a few "print-head-cleaning" cycles, to try to unclog it.
Recently renewed ink cartridges in Lexmark x4650 with genuine Lexmark replacements and keep getting one or two lines of 'wavy text' per page
This can either be blocked nozzles on the cartridge, or an alignment problem. Go to Start - All Programs - Lexmark - Solution Center and print out a Clean Nozzle Page and an Alignment Page from the maintenance tab. That should fix the issue.
My printer keeps giving the error "paper jam". I cannot find any kind of paper jam in it. Any ideas to fix this?
these printers will give this error if the main motor drive fails to initiate. its probably cheaper to buy a new printer
Cant copy A4 size
give print...select printer ....goto properties of the printer in the same dielog box.....then ....more page layout options .....there you can change the page scaling
Hi - I want to down load x4650 printer but I don't have the disk - please help me
go to the site of lexmark com netherlands driver software download section zoeken naar print drivers give in the x4650 and you get the files
":cj4600du32.exe ":
Sd card not being a removable drive in lexmark x4650?
YOU NEED A CARD READER FOR YOUR CPU ,,U CAN GET ONE FOR A A FEW BUCKS ,,THEN ITLL WORK FOR THAT
Comparable hp ink cartridge for lexmark x4650 printer
Yeah, here's my solution: Send the Lexmark printer back and bought an HP all in one.
Thanks
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
