Changed power cell and watch still not running
Movements become "dry" over time and must be serviced.
Another common problem we see is that there is oil or battery acid (from a previously leaking battery) inhibiting proper connection between the contacts and the battery.
The quartz and the circuit itself may also go bad on a movement at any time.
If it is under warranty, you may send it back directly to Lucien Piccard.
I recommend you visit your local Certified Master Horologist for what is usually a free diagnostic. They can test the battery, the connection, the movement, and usually repair, service, or replace the movement for you. They will also generally give a free estimate.
