Hello.
If your washer is indeed a WFL2066, than the not spinning is directly relatedto the unit not draining.
These machines by design cannot spin if the drain is inadequate.
Here is the first step in resolving the problem, you need to access the drainpump/filter to clean it.
To reach the filter and clean it...
**Unplug the washer from the dryer or wall, or turn off the 30amp breakerat the home service panel...safety first**
1) Open the small square plastic door at the right bottom of thewasher.
2) Via the small hose drain any access water from the pump...this is where awet/dry shop-vac comes in handy, or a shallow pan with a few towels works a swell.
3) Then turn the pump insert/button trap counter clock-wise and pull out.Clean the trap out thoroughly running it under hot water and mild soap or your washer detergent and inspect inside the pump for any other foreign objects/obstructions.
4) Re-install the lint trap insuring it is good and snug/tight. Before closing up the small access door, run a short rinse spin cycle to check frleaks.
Let me know how you make out, or if you require further assistance.
Thank you for visiting our site please take a moment to rate the info-provided for you here.
Thanks.
