KitchenAid KUDS01FKSS Dishwasher Logo
Anonymous Posted on Sep 26, 2011
Water fills and cycles fine. Arms do not spin; no cleaning. Circulation motor?
Anonymous
Level 2:
New Friend:
  • Expert 107 Answers
  • Posted on Sep 27, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
107
Questions
0
Helped
22490
Points
202
Either the motor or chopper is broken. If chopper is broken the screen will be clogged with food. If its clgged you can clean it and reinstall and see if theres any improvement. If so replace chopper.
2answers
Spray arms not getting good spin following circulation pump replacement
I would say that you still have blockage in the supply line or a fitter coulnd be blocked or in the spray arms . I did google this and that was I came up with ..
Mar 20, 2023 • Dishwashers
I have an Asko D-3122 dishwasner. When it is started on a normal wash cycle it drains, fills, heats the water if necessary and then stops. It does not go into the wash cycle. I assume the circulation...
If there is no sound of the circulation motor then it is faulty. But if the circulation pump sound is coming but water is not circulating then you need to check the wash arms for blockage.
Refer this diagram for location of parts in wash system
http://spares.bigwarehouse.com.au/images/files/19975_6146c636e8211a1ecc4ecdc062082148.pdf
Neither the upper or lower wash arms spin.
Circulation pump might be faulty. or spray arms are blocked. remove spray arms and clean them and try it again.
Ariston li 700
follow the steps and fix it. God bless you
Drain Pump
If the dishwasher is loud during operation, the drain pump might be defective or might have some debris in it. This is a common problem.
Circulation Pump
If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the circulation pump sound, it's likely that the circulation pump motor bearings have failed. Once this happens the circulation pump will have to be replaced, the bearings are not repairable.
Drain Impeller
If the dishwasher is loud during operation, the drain impeller might be broken, or there might be debris in the pump. Generally, to gain access to the pump the top of the pump housing will have to be removed.
Pump and Motor Assembly
If the dishwasher is loud the motor bearings, drain impeller or wash impeller might have worn out. All three of these components are part of the pump and motor assembly. It may be possible to replace one of the impellers, but the motor bearings cannot be repaired. In that case the pump and motor assembly will need to be replaced.
Wash Impeller
The wash impeller is a small, plastic blade. The motor spins the impeller forcing water through the spray arms to clean the dishes. If one or more blades has broken off of the impeller the dishwasher is loud. The impeller can also scrape against the pump housing if it is damaged, warped or bent.
Circulation and Drain Pump Motor
If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the motor sound, it's likely that the circulation and drain pump motor bearings have failed. Once this happens the motor will have to be replaced, the bearings are not repairable.
Water Inlet Valve
The water inlet valve is an electrically controlled water valve. When it is new, the water inlet valve is very quiet. Over time, the diaphragm inside the valve deteriorates and deforms. This deformation interacts with the water rushing in and can cause a loud vibration, buzzing, squealing or other noises. If the dishwasher is loud during the filling cycle, replacing the water inlet valve may solve the problem.
Jul 06, 2013 • Dishwashers
1helpful
I have a year old kitchen aid dishwasher and during fill cycle it makes a thumping noise. The dishwasher every 5 or 10 seconds shuts off fill cycle then turns back on which I think is what's causing...
Drain Pump
Enter your model number to see parts for your dishwasher.
Help me find my model number
Circulation Pump
Drain Impeller
Wash Impeller
Water Inlet Valve
God bless you255fe28d-9cc9-4874-b381-9c9de59f3f75.jpgc98d91d6-ba21-42ff-b684-98f0b3e856c0.gif
May 24, 2013 • Dishwashers
1helpful
I have a kitchen aid dishwasher KuDR01TJBLO noisy when draining
see this causes and fix it. God bless you
Drain Pump If the dishwasher is loud during operation, the drain pump might be defective or might have some debris in it. This is a common problem.
Circulation Pump If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the circulation pump sound, it's likely that the circulation pump motor bearings have failed. Once this happens the circulation pump will have to be replaced, the bearings are not repairable.
Drain Impeller If the dishwasher is loud during operation, the drain impeller might be broken, or there might be debris in the pump. Generally, to gain access to the pump the top of the pump housing will have to be removed.
Pump and Motor Assembly If the dishwasher is loud the motor bearings, drain impeller or wash impeller might have worn out. All three of these components are part of the pump and motor assembly. It may be possible to replace one of the impellers, but the motor bearings cannot be repaired. In that case the pump and motor assembly will need to be replaced.
Wash Impeller The wash impeller is a small, plastic blade. The motor spins the impeller forcing water through the spray arms to clean the dishes. If one or more blades has broken off of the impeller the dishwasher is loud. The impeller can also scrape against the pump housing if it is damaged, warped or bent.
Circulation and Drain Pump Motor If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the motor sound, it's likely that the circulation and drain pump motor bearings have failed. Once this happens the motor will have to be replaced, the bearings are not repairable.
Water Inlet Valve The water inlet valve is an electrically controlled water valve. When it is new, the water inlet valve is very quiet. Over time, the diaphragm inside the valve deteriorates and deforms. This deformation interacts with the water rushing in and can cause a loud vibration, buzzing, squealing or other noises. If the dishwasher is loud during the filling cycle, replacing the water inlet valve may solve the problem.
I have a whirlpool Adp8540 that seems to go through the wash cycle completely but when we open it up the water has not gone through the spraying arms and the soap is a solid mass at the bottom of the...
It is likely the water circulation system is faulty. This dishwasher uses a single motor to run the water pump and the drain pump. If you hear the wash pump operate during wash cycle then it is likely there is a blockage in the water circulation manifold which distributes the water through the arms.
If you do not hear the pump operate during wash cycle then the sensor is faulty. The sensor tells dishwasher to switch to drain cycle from wash cycle.
Try following the diagrams at top of this website to get idea of parts.
Oct 13, 2011 • Dishwashers
When the cycle has finished and I open the door the washing tablet is sitting in the tablet flap that is open
Hello Vanessa,
Welcome to FixYa.
Based on your description and provided the dishwasher is indeed 1) an Asko D1716 and 2) filling with water, draining, heating, but not dissolving the detergent, it often is a busted wash impeller within the main motor/circulation pump.
Unfortunately the impeller itself is not serviceable, the entire motor/pump must be replaced if indeed it is broke.
Here's something you can try first though, this will indicate if the unit is circulating the water properly. Try placing both spray arms at 12 o'clock position and placing a cup upright in the top rack. If the arms move and the cup fills, you've got circulation...if neither, you don't.
Also be sure the unit is actually filling with water, this image below indicates the normal water level to look for....
Let me know what you find and I'll try and help you move forward from there. If you need direction to remove the circulation motor and pump I can do that, but it is a pretty involved repair and requires pulling the unit from the cabinet. Check those other possibilities first and tell me what you find.
I'll watch for your reply.
Regards,
Macmarkus :)
No pressure during wash cycle
Motor pump has gone out. pump needs replacing. the unit needs to be pulled out inorder to access the pump. the sides of the d/w must come off.
Jun 09, 2008 • Dishwashers
2answers
Water not going through spray arms
1.does motor run? no. replace motor. 2.open door and leave the bottom rack inside dw.spin the spray arm underneath the bottom rack by hand. it should spin freely without binding. if it doesnt spin freely take out the bottom rack and try again. if it does spin freely then your bottom rack is laying on your sprayarm preventing it from rotating. 3.you could also not be getting enough water into your dw.
Top KitchenAid Dishwashers Experts
Mike Cairns
Mike Cairns
Paul Carew
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
