Samsung SGH-A877 Impression Cell Phone Logo
Posted on Sep 25, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need the puk code and new pin number i tried puttin a lock on my phone and i didnt know the code to change it because it was a used phone and now im locked out of my phone because now i need the puk code and pin number
Anonymous
Level 3:
  • Master 2,418 Answers
  • Posted on Sep 28, 2011
Anonymous
Master
Level 3:
Answers
2418
Questions
0
Helped
812696
Points
6999
These directions are for an AT and T phone, but other than that, are the same for any carrier. A PUK (PIN Unlock Key) code is required to unlock SIM cards that have become locked following three successive incorrect PIN entries. If your SIM card becomes locked, you will need to get a PUK code from your phone carrier to unlock your SIM card. You can obtain your phone's PUK code from your carrier in one of these ways: Log in to Your account.online Use a Technical Support Chat Contact your carriers Customer Care Get Your Phone's PUK Code Online Go to the Phone/Device page. From the My Phone/Device screen, select the Unblock SIM Card link under the My Make & Model heading. The Unblock SIM screen will display your PUK code and will give you instructions for unblocking your SIM Card. Once you receive your PUK code, you will need to enter it into your phone to set a new PIN code. Note: If you enter the wrong PUK code 10 times in a row, your SIM card will be invalidated, and you will need to purchase a new SIM Card. The phone will display the following error: "PUK blocked call operator
1helpful
2answers
These are my numbers 0796086761 and i need mt PUK please
Make the FixYa experience better for everyone by voting.
My name is Ben and I'm your guru, i.e., mentor, an influential teacher or popular expert: a management guru. - origin from Sanskrit, 'weighty, grave' for today.
Subject: How to unlock a SIM card
Customer's exact description: these are my numbers 0796086761 and i need mt PUK please
Discussion: Problems of this type can be easily solved. Customer did not provide the name of the service provider.
Solution: Provide instructions for unlocking a SIM card
PUK Codes
A PUK (PIN Unlock Key) code is required to unlock SIM cards that have become locked following three successive incorrect PIN entries. If your SIM card becomes locked, you will need to get a PUK code from AT&T to unlock your SIM card.
Since I don't know the name of you carrier, I'm using AT&T as an example. Most carriers use the same methodology though the wording may be different.
You can obtain your phone's PUK code from AT&T in one of these ways:
Take the phone into your carrier's retail outlet.
OR
• Log in to myAT&T online
• Use our Technical Support Chat.
• Contact Customer Care
To get your phone's PUK code online:
? Log in to myAT&T.
? From the myAT&T tab at the top of the page, hover over the Wireless link and select Phone/Device under the My Wireless Service heading.
? From the My Phone/Device screen, select the Unblock SIM Card link under the My Make & Model heading.
? The Unblock SIM screen will display your PUK code and will give you instructions for unblocking your SIM Card.
Note: If you enter the wrong PUK code 10 times in a row, your SIM card will be invalidated, and you will need to purchase a new SIM Card. The phone will display the following error: "PUK blocked call operator."
Second Solution:
You can also do it without any assistance from anyone. However, be sure to read the following carefully because there are pitfalls. If you want to try to do it yourself, just click on the following link: Universal Software Solution for Unlocking a SIM Card
Although most people remember their primary SIM PIN code, those other codes - used for various verification purposes - are never to be found when needed. Below I've included a set of short codes which, when entered on a handset's standby screen, will let you easily change PIN and PUK (short for Pin Unlock Code) codes - but keep in mind, they may not work with all handsets and mobile operators.
More importantly, when changing one's PUK codes there'll be no help to get from the mobile operator if the new codes are forgotten, so make sure to write any changes down alongside the old PUK codes.
The Final Solution:
The following methodology does not work for every phone. Perhaps you'll be lucky. Also, please note that the codes should be entered without the spaces shown below.
Change SIM Card PIN
** 04 * old PIN * new PIN * new PIN #
Change SIM Card PIN 2 (Write down the new code)
** 042 * old PIN * new PIN * new PIN #
Change SIM Card PUK (Write down the new code)
** 05 * old PUK * new PUK * new PUK #
Change SIM Card PUK 2 (Write down the new code)
** 052 * old PUK * new PUK * new PUK #
Display Handset IMEI
*# 06 #
This was wordy but hopefully it helped you.
Ben
*# 06 #
Ben
Sep 11, 2011 • Cell Phones
1helpful
ITS LOCKED AND I CANT UNLOCK IT I FORGOT THE SECURITY CODE I DONT REMEMBER PUTTIN ONE ON THERE
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Default 6 Digit Security code: 000999 or 1122
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
OR:
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
2answers
I want to know my pin & puk code easily
If you have forgotten your PIN number;
  • Telephone your cell phone service provider and ask for your PUK code. (They are the only ones who can give it to you as it's the SIM card that locks rather than the phone.)
  • Enter a wrong PIN number 3 times and your SIM card will lock (if it's not already locked)
  • Turn off your phone and then turn it on again.
  • When you turn it on enter the PUK code. It will ask you for a new PIN. Enter a new PIN number and that will be the PIN you use from then on.
Keep the PUK code safe somewhere as you could need it again if you forget the PIN again.
2helpful
I was messing around on my phone and i was going to try and make a new pin to lock it. i couldnt figure out the pin number because ive never messed with that before and the it said pin code blocked enter...
More than likely you will have to call your service provider. The PUK means your sim card is locked. You can try 111111 or 000000 but usually you have to call and they will you walk through unlocking it. By the way your orginal password is usually the last 4 digits of your phone number. one last note sometime you have too call more than once because not all techs know what they are doing.
Dont know pin number for phone how do i change it
contact service provider for puk code
Mar 20, 2010 • Cell Phones
1helpful
I want set a pin code, but cant, n tells me i keep puttin wrong 1 n only have left 1 try,the person who had it said never had code 4 it?? what do i do
Pin codes are specific to the sim card and can only be obtained from your service provider by reading them the sim card number. you can set a phone lock with a security code or call your service provider and get the pin... If you enter it wrong it will say puk code and then you'll need a new sim card. call att 1800-331-0500
Locked
you have to enter sim codes for your phone to work in different places
2helpful
4answers
Puk code
please help my sim card is puk lock i nedd a code to unlock it
Dec 13, 2007 • Nokia 6600
Top Samsung Cell Phones Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
