I have a Magicolor 1690MF lazer printer
after I print one page i get an error "paper size error
reset paper (1A4) press Start key
doing this it automatically prints the same document again and this whole process starts over again ...i have the same problem with this guy...
Re: I have a Magicolor 1690MF lazer printer
after I...
If you still get the paper size error as I did on my 2480MF, change the Media type from plain paper to cardstock. Worked for me, of course I use 24lb paper.
Everything you checked sound good. Might be printer software problem, and needs to be re-flashed. Software only available from secure web site that a technician would have, see what it cost if to much buy a new one with extra bells and whistles !
The Konica Magicolor 1690MF Printer/Copier/Scanner is connected with an Ethernet Cable or USB Cable. It is not equipped to operate as a wirleless printer. It has a 10Base-T/100Base-TX Ethernet interface port and a USB Revision 2.0 High-Speed compliant port.
To do two-sided printing you must have the duplex (double-sided) option installed. This also requires either Tray 2 or the Attachment to be installed underneath your machine. Tray 2 is the optional lower feeder unit which increases capcity of your machine to 500 pages. The Attachment comes with the Duplex Unit.
Only Letter and A4 plain paper (16-20 lb bond) can be autoduplexed. With the duplex accessory installed you can do duplex or double-sided printing automatically.
From within Printer Preferences select Two-side Printing > Automatic. Shoud have choices of Off, Manual or Automatic. Within the Layout Tab for your work you may also be able to specify duplex (double-sided).
Should you have continued difficulty, please reply and advi e if the duplex option is installed and with which software and operating sysytem you are using.
Thank you for using FixYa!
Please check the settings in your printer that you have selected correct paper type and tray from which you are printing. Also while giving print command make sure paper size is same.
Test the driver. Go in the properties for the printer and set the number of copies to 4. Try to print a Windows test and and see if you get the same error message. If you do, then the issue is the paper settings in Printing preferences and probably needs to be changed to LETTER paper. If you don't get an error message, the issue is the application you are printing from. Make sure the application is set to letter under printer setup.
