SOURCE: remote control sensor broken
it is best to take it to a shop should cost no more than 15 quid you can do it yourself but it is a bit fiddly and you can damage something else doing this hope this is some help the part should cost about a fiver
SOURCE: How can I turn to AV without a remote control (Samsung TV/VCR 19in Combo)
I had this problem with my TV/VCR combo unit (Samsung CXC1972) after losing the remote while in the dorms. I tried a few different universal remotes and dozens of codes before I tried the Philips 3 device universal remote as pictured below with code 037 programmed into the VCR/DVD button. I can't change the volume with this code but the input key switches between line in and tv. You can also change the channel, access the menu and operate the VCR functions with the code. I bought the remote for less than $10 at Walmart so it might be worth a try, and if it doesn't work you can always bring it back. Hope this helps.
SOURCE: Samsung WS32Z308P TV has tuned out
I rand the Samsung help desk and they guided me through how to reset the TV back to its original factory settings. This solved the problem.
SOURCE: remote not working!
Hi, I have just had same problem and rang Samsung who sorted it ! All that was required was to reset remote by taking out the batteries then press power for approx 10 seconds and then replace the batteries and hey presto it worked!
I had the same problem. The problem is strange and seems to be with the receiver in the TV and not the remote control. The reason I say this is that when this first happened my Samsung brand DVD could actually control the TV. This then also failed, but still works fine with the DVD player.
Anyway there is an even more bizarre fix to all this......
- Remove the batteries from your TV remote.
- Press and hold the red (ON/OFF) button for at least 1 min.
- Replace the batteries and hey presto!!
I know seems far fetched but I found it on the Samsung website and it does work.
The flashing blue light shows that the TV is receiving I.R. from the remote but doesn't mean that the signal being received is recognized by the Samsung. If you have a "universal" remote then your TV code may need to be re-entered/reprogrammed...changing batteries in a "universal" will usually require it to be reprogrammed. Also...because of the remotes construction (rubber membranes with carbon dots that short across PC traces) I've seen certain buttons stop working altogether.
