Question about Texas Instruments TI-84 Plus Silver Edition Graphic Calculator
How do i divide scientific notations? - Texas Instruments TI-84 Plus Silver Edition Graphic Calculator
  • Texas Instru... Master
  • 8,081 Answers
Exactly as you would any two numbers. If you are not comfortable with the notation enclose each number in scientific notation between parentheses. This way you can be sure that the priority of operations is respected.
Posted on Sep 19, 2011
SOURCE:
How are numbers in scientific notation entered in Aurora SC150X calculator
Look for a key that is marked EE, or Exp, or x10^x. To enter a number in scientific notation, you enter the decimal part, then press the Enter Exponent key, followed by the exponent. If exponent is negative, you precede it with a press of the change sign key (-).
Once a number is entered there is no special treatment: multiply it divide, or add it.
Mar 16, 2012 | Aurora Electronics SC150X Scientific...
How does one enter a number in scientific notation in SC150X calculator
Just got a SHARP EL-531X, it won't do simple calculations with scientific notation, It keep saying
To enter the power of 10 with exponent use the Exp key followed by the exponent. If the exponent is negative, you must use the negation key (-) not the - key (for subtraction).
When you press the Exp key you do not type in the 10.
Mar 10, 2012 | Sharp Office Equipment & Supplies
I need to know how to divide, mutiply, add, and substract in scienctific notation on my Casio fx-300ES
The "problem" is not how to calculate with numbers expressed in Scientific Notation but how to enter a number given to you in scientific notation. Once the number is entered you do not have to do anything special. If you have to multiply it use the (x) button. to add it use the + button, etc.
How to enter a number in scientific notation.
Type in the mantissa (example 6.022)
Press the [X10^x] at the bottom of keypad.
Enter the exponent (example 23)
with this example you will have entered Avogadro's number 6.022x10^23
Other example
1.6 [X10^x] (-) 19 enters the electron charge in Coulombs. The exponent is negative that is why you press the change sign key (-).
Aug 24, 2011 | Casio fx-300ES Calculator
I have an Casio fx-300ES, and im taking an honors physical science class and i need to know how to divide/multiply/add/subtract in scienctific notation. For example: 6.25x10(to the negative 4) / 4.1x10(to...
All you need to know is how to enter a number in scientific notation. As to the operations you do them the usual way: For example, to multiply you enter a number (in any notation) press the multiplication key then enter the second number (in any notation) and press the = sign to get the result.
The problem is that the result may not be in scientific notation format. But for that you can configure the calculator to always show results in scientific format. Here is how to force that. Press [SHIFT][MODE] to enter (SetUp). In the screen that displays enter the number for the option SCI. You will then be prompted to specify the number of decimal digits. You will enter a number between 0 and 9. If you select 0 you will not have decimals in the result, and if you enter 9 you will have 9 decimals. What is the appropriate number of decimal place to keep in the FINAL result will depend on the number of significant digits in the measuremnets.
To enter a number in scientific notation (ex: 6.25x10^(-4))
You enter the so-called mantissa 6.25
You press the key at the bottom of keypad that is marked as [X10^x]
You enter the change sign (-) followed by the exponent 4
If your calculator is in MathIO you will be able to verify that what was entered is exactly what was neant. In MathIO, you move cursor up or down using the Up or Down arrow. When you finish entering the exponent you use the right arrow to bring cursor to the main level.
Convert to scientific notation 45,700
45 700 = 45700.00..... Notice the decimal mark inserted after the second 0.
In scientific notation you must have ONE digit before the decimal mark: 4.7500 (it is not finished).
By moving the decimal mark from its original place after the second zero to its new place after the 4, you have divided the number by 10000 (one zero for each position change). To recover the original number you must multiply 4.57 by 10000. This is compacted as *10^4.
Thus 45700=4.57*10^4 or as the calculator displays it 4.57E04
If you are entering a number in scientific notation do not use *10^04, but press the [SHIFT][,] for a TI83Plus, followed by the exponent.
Jul 12, 2011 | Office Equipment & Supplies
I have a TI30XA calculator and want to know how to multiply numbers using scientific notation. I have learned how to enter a number (e.g., 1.5 x 10 -6), but when I try to multiply it by something (e.g.,...
Press 2nd [SCI] to switch the calculator to display all results in scientific notation. The results are the same whether you do it in scientific notation or not, it's just how the number is displayed.
Feb 13, 2011 | Texas Instruments TI-30XA Calculator
So i keep trying to divide...and my answers are all coming out as fractions and i tried what was listed below, but that only makes the answers come in scientific notation, so how do i make the answers...
Press SHIFT MODE 8 2 to select the Norm2 display mode, which will display in fixed decimal notation unless the magnitude of the number is larger than 10^10 or less than 10^-9
For more information about the display modes, please refer to your manual.
Sep 22, 2010 | Casio FX-115ES Scientific Calculator
After working a simple problem adding numbers in scientific notation, I want to convert the answer, a decimal, to scientific notation
For converting answer in to scientific notation do the following steps.
1.click shift key after that press mode key next to on button.
2.From the menu that is displayed in the screen press 7 for displaying answer in scientific notation.
Thank you.
Jun 10, 2010 | Casio FX-115ES Scientific Calculator
I have a TI-30XS Calculator and cannot figure out why the thing won't work when I try to divide numbers with scientific notation. The calculator appears to be adding exponents when it should be...
One solution that you might try is to put the scientific numbers in parentheses. For instance open parenthesis, type in the first scientific notation then close parenthesis, next hit the divide key and then open parenthesis and type in the 2nd number in scientific that you are dividing by and then close parenthesis. Hit enter or =. I'm not sure if this will fix your problem, but it is worth a try.
Aug 28, 2009 | Texas Instruments TI-30XA Calculator
Texas Instruments TI-84 Plus Silver Edition Graphic Calculator Logo
104 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Steve Allison
Steve Allison
Ekse
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
