Please Install Calculator Software Now error
This message means that the operating system has been corrupted. These steps will allow you to update the OS.
Unit to Unit
• Connect two TI-83 Plus units by means of the data cable (short black cable that was prepackaged with the TI-83 Plus)
• Make sure that at least one of the TI-83 Pluses contains the current Operating System
• Select [2nd] Link
• Select "Send OS" option from the Link menu
• Make sure that the other unit still reads "Waiting Please Install"
• The OS should be downloading.
From the Computer
• Make sure you have the latest version of the TI Connect™ Software
• Download the latest version of OS for the TI-83 Plus to the desktop of the PC.
• Connect the appropriate TI-GRAPH LINK™ cable between the PC and TI-83 Plus.
• Since the TI-83 Plus is currently off, the TI-83 Plus will automatically turn on when the TI-GRAPH LINK Cable is inserted.
• On your computer, choose Start, Programs, TI Tools, TI Connect, TI OS Downloader.
Press [2nd][APPS] to open the (ANGLE) menu. The symbol for the minutes is the second in the list. To enter the seconds press [ALPHA] [+]. When entering an angle in D(egree)M(inute)S(second), you must enter the number of minutes even if it is zero. 12 deg 25" will give a syntax error, so you have to type 12 deg 0' 25"
Hello, Well, if screen shows the RAM CLEARED message, that means your calculator is working. Just press the [CLEAR] key, message will be erased and you are ready to crunch numbers.
Ti 83 and ti84 really have no difference and operate the same. There was something different or you had varibles used by multiple programs that conflicted w/ the ti84 and it would have done the same on the ti83. If you like to rework it and need help email me at [email protected]
I reccently had the same problem, but I have a Ti-84 Plus,and I am disgusted by how poorly this matter is covered by Texas Intruments. Esp. since the solution is rather simple.
The antilog key is [2nd] [log] or the 10^x. On your screen it should apear as 10^( and then you just input the value that you want to find the antilog of.
When used to solve pH problems remember to input the pH value as a negative number, since pH= -log[H+] then [H+]= antilog(-pH).
