Hi Turn the freezer setting to a lower (not as cold) temperature, and then pour hot/warm water over the tube in the freezer that provides the water for the ice. Yes, the water in the tube may have become frozen. To access the drain, remove the items and shelves in the freezer, then remove the lower rear panel... there are 2 screws holding it in place about 2 feet up from the bottom. When you have the panel out, you'll see the drain below the evaporator coil... take that back, you won't actually see the drain 'cause it's covered by ice, but it's there. Please get back to us if you have further query or else please accept the solution. Thanks for contacting fixya.com
You can use a turkey baster to suction up water, and an aluminum pan to catch the run-off.
Use a hair dryer to melt this block of ice. Then remove that aluminum shield that's sitting there... this will expose the actual drain hole. What I do at this point is pour some very hot water (not much, about a cup) into the drain to help thaw the ice in the drain and use a small flat head screwdriver that's about 4" long to poke/scrape/dig in there and help it out.
Ice bin must be locked in place for proper ice dispensing. If necessary, turn auger driver behind ice bin counterclockwise to properly align ice bin with auger driver.
• Press the switch ON to activate ice maker. Slide bin into guide rails located on either side of the enclosure. Push the ice bin in until resistance is felt. Raise the front slightly and push the ice bin completely in. An audible "click" is heard when the ice bin is located correctly.
• After freezer section reaches between 0° to 2° F (-18° to -17° C), ice maker fills with water and begins operating. You will have a complete harvest of ice
approximately every hour.
• Allow approximately 3 to 6 hours after installation to receive first harvest of ice.
• Discard ice created within the first 12 hours of operation to verify system is flushed of impurities.
• Stop ice production by pressing the ON/OFF switch located on the front of the ice maker.
• The first one or two batches will probably contain undersized and irregular cubes because of air in the supply line.
• When the ice cubes are ejected it is normal for several cubes to be joined together at the ends. They can easily be broken apart. The ice maker will
continue to make ice until the supply of ice cubes raises the ice maker arm, shutting the ice maker off.
• Certain sounds may accompany the various cycles of the ice maker. The motor may have a slight hum, the cubes will rattle as they fall into an empty storage bin and the water valve may click or "buzz" occasionally.
