SOURCE: Trouble with my cyberhome ch-dvd 300
I have the same model player it pauses some of the times on some disks in some locations, I read at videohelp.com a resolution for this for skip frames for those who use PAL and mine skip frames after pausing though I have not tried PAL perhaps this remote code solution might fix this or some have had firmware updates though I could not find any firmware updates as any solution by CyberHome being this happens only happens some of the time it might not be possible to resolve this and taking it to a repair shop likely would not be worth it I am unsure if some software versions helps this Please let me know what you find out, okay? Email does not always go through, hence if you do not get a reply in 24 hours after you email me please try to contact me else how, okay? What is your name address and telephone number?Simncerely, Steven Bolin (206)937-2467 2851 SW. Yancy St. Seattle, WA 98126-2543 (206)937-2467 [email protected]
SOURCE: dvd player wont open
Look on the bottom of your player. Between the two front feet you should see a narrow slot that is about 1 1/2" long (it should say "emergency hole". Shine a light into the slot, you should see a black pin about as big around as a pencil lead. Carefully push this pin in the direction of the arrow. It should release the drawer and allow you to open it.
SOURCE: Cant play anything on it
I had the same problem, After googling for a few minutes I found the reset procedure for this player.
1. Turn it on.
2. Eject any disk you have in there and close the tray.
3. Hold down the "STOP" button on the player (not remote) until the green light flashes red and the system reboots.
4. Insert disk and enjoy.
This worked for me... mileage may vary.
SOURCE: cyberhome 300 dvd player
try to pull the tray all way out by hand 1st knda resets it then hit close
SOURCE: dvd player keeps saying no disc when I try to play
dvd player keeps saying no disc when I try to play a dvd.what can i do? worked fine until about 3 months ago. started to say no disc when disc inserted but after opening and closing 3 to 6 times it would read.now it just wont read. any ideas?
