Press and hold adjust button until digits flash (the digit that flashing is changeable by reverse and forward) mode is to choose what you are about to change. if your done with the digital time, press adjust once. for analogue time: press mode button until it reaches the word "H.SET" press and hold the adjust button then the word H.SET replaced by the time that you had been set for the digital time. then you can now use the reverse or forward to set the analogue time. if your done press the adjust button once then the mode button once. i hope i had been helped you.
Need help...have try to change the battery...after changing it to a new battery...no display and everything is not working...any clue in how to slave it..tks
