Check the cabinet is properly leveled and standing firm without twist or rocking.
If there is adjustment available on the door hinges ensure each is correctly adjusted to a very high degree. Ensure each door is without twists.
Check each closing surface is smooth clean painted steel and check each door seal is still soft and supple and hasn't hardened and lost flexibility. Check each door closes without gaps.
Nothing more can be done so if a door does pop open when another is closed, try closing the door more gently to prevent both shock to the cabinet and an internal pressure wave.
Replace the failed door seals
SOURCE: Freezer was left ajar & now Refrigerator does not work properly
you have ice build up on the evaporator. two ways to cure. first switch off for 24 hours and leave with doors open. second switch off. remove back panel inside freezer and melt ice off with a hair dryer
SOURCE: Sub zero refrigerator freezes food
Hello. You need a new cabinet thermistor and while you are at it replace the evaporator thermistor. (The evaporator is the cooling coil behind the back wall of your fresh food section) . These sense the temperature in your frig. Both of them are behind the back wall of your fresh food compartment. You will need a wire crimper and a heat gun or lighter to heat shrink the wire connectors that come with the new ones.
SOURCE: Amana BX20RW Refrigerator slightly warm freezer not freezing
Check the thermostat, to make sure that it is working properly. The theremostat is a long wire in the top of the freezer up near the fan. If that is bad it will not let your freezer cool correctly
SOURCE: refrigerator door pops open, frigidaire top
The refrigerator needs to be perfectly leveled side to side dn should pitch back slightly. Also look at the plane of the doors, that is to say that they should be squared to the cabinet. If they are sagging, you may need to adjust the hinges.
SOURCE: bottom of refrigerator is not cooling
Hi: Is your freezer so full it's blocking the vents? If so unblock the vents. If not put your food in a cooler, frozen and fresh. Unplug your refrigerator. Take a hair dryer to the back of the freezer to melt frost accumulated behind the panel. I know it's supposed to be frost free. You have a problem with the defrost heater or the timer. The frost is blocking the vents. Most likely it is the later, but if you see no frost it could be the circulating fan. The location of these will be in your parts list. Kenmore still gives these with their products. If you don't have it go to sears.com and use parts direct. They will have a diagram. I hope this helps, Jeff By the way, If you are not handy just do the hair dryer thing and it will work for a weed or two until the frost plugs it up again.
