SOURCE: drs2662aw amana side by side
Sounds like you may have a restriction or blockage, may also be low on freon
SOURCE: GE side By Side GSS22JEMDWW
Maybe but there is also a thermister in the defrost system that might be bad. The thermister is a small, white, barrell shape and is as big around as a pencil, It has 2 wires going in it and is attached to the top of the coils in the freezer.
SOURCE: GE TFX27PF refrigerator and freezer still not getting cold enough
the partial frost pattern is an indication of low refrigerant, restriction or bad compressor. if the unit is under 5 years old this repair will probably be under warranty thru GE. if out of warranty then you are looking in most cases between 200-500 dollars for repair. good luck Thanx peyton
SOURCE: Evaporator coil frosted up on Samsung RS267LABP Refrig side
TAKE AND DISCONNECT THE POWER TO TH UNIT AND ON THE VERY BACK THERE IS A CONTROL BOARD THE IS UNDERNEITH A WHITE PLASTIC COVER THAT YOU WILL HAVE TO REMOVE THEN DISCONNECT AND RECONNECT THE WIRES TO THE CONTROL BOARD AND SEE IF THAT DOESTHE TRICK.
SOURCE: My GE fridge is not defrosting the coils in the back. What's up?
if u have frost build up in the freezer it will affect the temperature
and it needs to defrost
problems could be
defrost timer.
thermostat.
terminator.
heater s.
unit problems (unlikely) if even frost coating.
