Probably a cartridge issue. Get them cheap on ebay. eBayeBay
SOURCE: HP F380 printer
This happens when your print head gets dirty. Just claening the print head should solve your problem. To do this: Click start button > click Printers and faxes. > Right the printer icon > click properties > Here you should find something like "Head cleaning" or "Clean the print head". This option can be used to clean the priter head automatically. If it does not work, you can manualy take out the cartridge and dip it in to IPA (Isopropyle alcohol) solution would clean the head[dip the head only not the complete cartridge]. After a few minutes (10-20) you can fit the dry cartridge the printer. If nothing works try changing the cartridges. Note: When the ink is running out this may occur. The only thing we can do is to replace the cartridge.
SOURCE: HP PSC 1350v Check Print Cartridge Light
Check the date on your ink cartridge. I bet it has expired. If you put in a "new"cartridge but it is even an HP one with an older date, it may not work.
I had my printer stop in the middle of a print job. It was printing fine and suddenly would not print. So I refilled the cartridge with an ink kit I had on hand and reinserted it--no go! Then I opened a remanufactured cartridge (office depot) I had bought some time ago and inserted it. No go, despite the fact I could see ink coming from the jets. I finally gave up and bought a new HP ink cartridge, and it worked just fine. But it bugged me why the new one would work and the other two that seemed just fine would not.
Later I learned that HP has a chip that reads the expiration date on the cartridges and that is what keeps those old ones from printing. I found one trick of setting my date on my computer back to a year earlier than the exp date on the cartridge. I saw the date on the remanufactured one I had tried earlier was 2005, so I set my computer date to today date but year 2004. After forcing me to do print alignments several times and take the remanufactured cartridge out and put it back, I got it to print just fine. And that 2005 cartridge that would not work earlier is what I am printing with right now.
Be advised, though, if you try the date setback, that HP printer will buck and try every way to not let you use that old cartridge. You must say no to reflashing if HP tries to pull that on you. And you will take out and put back that same cartridge multiple times and keep printing alignment sheets 3 or 4 times before you are successful. But, if you persist, you can get it to work.
SOURCE: HP psc 1350 HP 57 print cartridge
Same problem with me.
So:
I openede the whole box ( 4 screws ) in the corners. Then I presed the tiny belt on the left side to its socket, cleaned the contacts of the cartridges (56,57) with water and made them dry.
Then I reched the position of the small door which is ment to be opened once you wnat to replace the cartridge.
After this the printer works again.
SOURCE: 4315 Hp Printer will not align.
restart your printer like this: go to control panel>
performance and maintenance>administrative tools> services> scroll down until you come to print spooler, click on this then on the upper side of your screen you will see restart, click on it.
This should get you up and running. Shame on your repair man for not showing you how to fix the problem.
You could even try not aligning the cartridges, this will just cause your printer to spit out an alignment page each time you turn it on but still should go ahead and print for you.
let me know how if this helps.
[email protected]
