Frigidaire ATF6000ES Front Load Washer Logo
Colette Smith Posted on Feb 17, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Frigidaire Affinity front load model #ATF6000FS1, when the start button is pressed it automatically goes into pause mode. I have tried resetting by pressing the "spin speed" and "soil" buttons but this isn't working either. Can you help? Thanks in advance.
vince
Level 3:
  • Frigidaire Master 2,530 Answers
  • Posted on Feb 17, 2018
 vince
Frigidaire Master
Level 3:
Answers
2530
Questions
0
Helped
748885
Points
8845
"pause" isn't something you can reset exactly I'm afraid. Pause means that the washer door was opened mid cycle so all you should need to do is shut the door to restart the cycle. Unfortunately if it doesn't re-start, it means that your door latch assembly has failed and isn't sensing that the door is shut. You'll need to order and replace the door latch assembly to fix the issue.
It's actually a fairly easy part to replace if you're handy. You'll need to unplug the washer and open the door to start with. Then there is a wire ring around the front lip of the rubber door gasket. Use a flat head screwdriver/needle nose pliers and pry the wire ring off. From there you can pull the gasket back out of the way. Remove the screws going into the door latch from the front and reach behind to replace the door latch assembly.
Make SURE the door strike on the door isn't broken too.
that's only a 6$ or so item.
Here's a site for parts and a video on how to replace it.
https://www.repairclinic.com/PartDetail/Door-Switch/131763256/4547033?modelNumber=ATF6000FS1
Hope this helps you.
5 Related Answers
IFIXALL
Archie Ferrarini
  • 869 Answers
  • Posted on May 21, 2008
SOURCE: Pause Error - Frigidaire Affinity LTF6000ES0
If you just paused the washer and now displays a error try draining any existing water all out of the machine.Before re filling it see if you still get the error message.I'll be happy to guide you through this.
Anonymous
  • Posted on May 02, 2010
SOURCE: My Frigidaire Affinity washing machine says it
my affinty washer is stuck in pause mode
Anonymous
  • Posted on Aug 21, 2010
SOURCE: frigidaire affinity washing machine pause error
Because our machine was new and covered under warranty, we had a maintenance person come out three times for this issue, but the only solution he could provide was to use less soap. Apparently, too much soap disrupts a sensor. So, if you let the machine run without adding any more soap, it will (theoretically) fix the problem. And this solution did work, to a certain extent.
Even though I started using much less soap, the problem is still persisting. For awhile, I was successfully able to fix it by running a few cycles without soap. Now, however, it just won’t work. Maybe others will have more success with this solution than we did.
At this point, the washer is no longer cover under warranty and our best solution is to buy anything but a Frigidaire or related Electrolux product.
Anonymous
  • 1554 Answers
  • Posted on Nov 13, 2010
SOURCE: I have a Affinity frigidaire front load washer and
Disconnect power then open the door and remove the spring-hoop assembly that secures the door gasket. Peel off the part of the door gasket near the door lock and switch assembly. Remove the screws securing the door lock and switch assembly to the front panel then pull the door lock and switch assembly out. Transfer the wires to the new door lock and switch assembly then install into place. Put the door gasket back and secure it with the spring-hoop assembly. Click on the link below for the detailed procedure.
Replacing the Door Lock and Switch Assembly on Frigidaire Affinity and Gallery Front-Load Washing Machine
Anonymous
  • 4323 Answers
  • Posted on Jun 06, 2011
SOURCE: Frigidaire Affinity LAFW8000L will not
Hi
The issue is with the door lock assembly that is bad and should be replaced. If the door lock assembly is bad the control will sense that the door is open and so will not start a spin cycle. If you want you can test the door lock assembly with a voltmeter before replacing it. Hope this helps...please post back for further assistance.
Daniel
What are the cubic feet for the affinity atf6000fs1
Hello Friend, this is Z. That's a great question!
I show that your Frigidaire Affinity washer (ATF6000FS1) has a total capacity of 3.5 cubic foot. Hope this helps! If there is anything else that I can help you with, please feel free to reconnect.
1helpful
My FA ATF6000FS1 has a "paused" error message machine wont function
Hi Alex, thank you for your inquiry!
"PAU" commonly indicates that the unit thinks that the door is not securely latched or the cycle has been interrupted. Try pressing "PAUSE/CANCEL" or "START/PAUSE" once to resume washer. If proves to be ineffective, try reprogramming the appliance by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and then turn your washer on. If the issue persists, then the washer could possibly have a faulty door latch or experiencing a communication error with the control board. I would personally contact a professional to accurately diagnose the washer to determine the root cause to reduce the risk of unnecessary parts.
1helpful
My Frigidaire Affinity is brand new. Just did our first load of laundry and mid cycle it stopped and the PAU is lighting up intermittent with the time left. I have tried everything I can think of and it...
Hello Mary Fortner - It means that the washer has been paused; the cycle has been interrupted. Either the "Pause/Cancel" button or "Start/Pause" button has been pressed. To resume wash - press "Pause/Cancel" or "Start/Pause" once. If this does not prove to be successful please turn the breaker to the unit off for 5 minutes. Then turn the breaker back on to the unit, and retry the cycle setting again.
My Frigidaire Affinity front loading washing machine model #ATF6000FS1 won't spin when loaded.What's the problem?
sounds like you have something in your pump stopping the water draining it will not spin with water try unblocking the punp
Frigidaire affinity error code 12
Clear code, exit mode and start dryer. If problem persists, replace Main Control Board
Every time I press start the washing machine goes into pause when pressing start button
its most likely a faulty button, press start once again and it should start the cycle. usually the start and pause buttons are the same ones.
8helpful
3answers
How do I reset my Frigidaire Affinity Front Load Washing Machine? When I press a button the ERR code comes on and then it turns off.
My Fridgidaire Affinity front load washer has a ERR pause and I can't reset it. How do I clear this
The washer is stuck in pause mode. How do I get
Control Lock To avoid having someone accidentally start or stop the washer, press Options and Select at the same time and hold for 10 seconds until “LOC” is displayed alternately with the estimated cycle time. To unlock the controls, press Options and Select at the same time and hold 10 seconds until ”LOC” is no longer displayed.
Machine stuck on pause/err
un plug the washer for 5 minutes and re try
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
