Caring For Your Venta-Sonic Humidifier
IMPORTANT!
Always unplug the unit before cleaning!
When to Clean Your Humidifier
Clean your humidifier weekly or more often during heavy use, depending on your
individual water quality. Clean your humidifier before storing and after long periods
of storage.
When cleaning the inside of your unit, keep water away from the air outlet. Exterior
may be wiped with a damp cloth when unit is off and unplugged.
Cleaning the Oscillator and Water Sensor
Turn off the unit and unplug power cord. Remove tank from base and empty
reservoir in base. Use cleaning brush provided in base to clean off mineral deposits
and sediment from oscillator and water sensor. Do not scrape or clean with tools
that have metal parts. Be careful to not damage the surface of the oscillator.
ATTENTION: Damage to the oscillator may cause the unit to not work properly.
The oscillator (ultrasonic transducer) is highly sensitive. Keep this important part
clean and treat gently. Do not touch the oscillator while the unit is operating.
Do not use soap, cleaning agents, detergents, or other chemicals for cleaning the
tank and humidifier.
After cleaning fill water tank (see instructions above) and return tank to base.
Storing the Venta-Sonic
Switch off and unplug power cord from A/C outlet. Empty remaining water from base
and tank. Clean tank and unit (see for instructions above). Make sure all parts are
thoroughly dry—allow at least 24 hours to dry. Leave the filling cap of the tank
loosened. This will keep the cap and gasket from sticking together. Pack Venta-Sonic
in original packaging and store in a cool and dry place.
You can find your manual at this link:
http://www.venta-sonic.com/pdf/vs207manual.pdf
Good Luck.
Power light blinking green and no mist.Fan not spinning either. I just brought this out of storage.
I have a Venta sonic humidifier that was purchased the end of Nov. 2013. it now makes a clicking noise as tho the machine is cycling on and off for the mist. Very annoying at night when we need it most. Any suggestions?Although this unit gets good reviews, it seems it has many problems and the customer service is poor.
our Venta sonic humidifier makes a clicking noise as tho it is cycling on and off to create the mist.
The float might be stuck. Lift the tank off the base unscrew the Phillips screw on the white tower remove the round float. Clean float and inside the float container. Replace float.
