Samsung LN-S4041D 40 in. LCD HDTV Logo
Posted on Aug 19, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Samsung HDTV takes almost a half hour to turn on. I push the on/off button and nothing seems to happen. I do have the TV connected to cable but even when I use the Samsung remote or the button on the side of the TV, it takes too long to turn on. My model is LN40A550P3FXZA, serial ALXR3CSQ502041W. I would appreciate some assistance. Thanks
Abctay.com
Level 3:
Master:
  • Samsung Master 372 Answers
  • Posted on Oct 30, 2018
Abctay.com
Samsung Master
Level 3:
Master:
Answers
372
Questions
Helped
212284
Points
1385
Https://www.Abctay.com is an tv parts online shop ,
We sell television and electrical accessories,all kinds of TV parts include power supply board, logic board, TV LED screen,
TV LCD screen
Chi Chu
Level 3:
  • Samsung Master 8,457 Answers
  • Posted on Aug 19, 2011
Chi Chu
Samsung Master
Level 3:
Answers
8457
Questions
0
Helped
2823018
Points
26282
Tv have a power supply board problems.That the board where the tv power a/c cord plug into it.Take the tv aparts and check the tv power supply board carefully for dying and leaking components parts that are calling capacitors parts these capacitors parts are most likely bugles ups or puffing up onto it tops and leaking.These capacitors parts are dying and leaking that why it give the tv power supply board low power and long time to power up the tv.Have all the tools and know basic electronic also can do basic soldering work?Yes,than changes all these dying and leakages bulges ups capacitors components parts with the same Miro Fared and thoes voltages on the capaictors parts like 5 or 10 volts higher than those capacitors parts was in the power supply board u are replacing,these 5 or 10 volts higher rating will help these newly replace capacitors parts withstand heat better and last longer and the operation on the tv power supply board.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv power suply board for the replacement.
Samsung HDTV black screen no picture no sound
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Samsung HDTV no picture no sound
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
I bought a Samsung 22"
This tv have problems with it tv Tuner signal board.That the board,where it take the incomming broadcasting signal cable and external devices inputs into it.Tv is still less than a year old,call for Samsung for a warrenty repair.Out of warrenty,tries websites like Shopjimmy.com,Ebay.com to buy a refurbuish tv Tuner signal board for the replacement.
3helpful
SSP-R4232 Plasma TV, blue light on, but tv wont turn on.
At this point it appears that your main board is probably bad. You most likely have a 5 volt scource going to the main board but its not powering up the set. The main board is part number BN94-00796A.
You might want to have a technician look at the TV to verify this as the issue before purchasing it. Please take a few moments to rate my answer. Thank you.
I want to figure out how to get the picture in picture and the half and half screen on my tv. It's been done before. It's a Samsung PLasma. What do I push on my remote?
If there is no PIP button on the remote then the PIP functions was that f a cable box. If you are connected to a cable box you are only supplying one channel at a time and you will see only one image.
I have a Samsung HLN437WX DLPTV. The problem that
no if the lamp works fine for hours , could be a signal problem check signal connection and wiring
4helpful
2answers
TV will not Turn On.
same thing,tv won,t come on,unplug the tv, nothing at all,just yesterday my tv was fine, this is the first time this has ever happen
Green and purple ghosts
Try to reset first if nothing happens we proceed another solution;
Resetting the TV
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can saved time.
1. Unplug the TV power cord from the power outlet for 3 - 4 hours.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
LG 50PC5D 50 Plasma Won't turn on
If you check underneath the t.v there may be a button that you need to push. then you can use the remote to turn it on. took about 2 hours before I found it.
mine is located on the bottom left, right underneath the screen.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
