SOURCE: why there is only japanese
Press the [MENU] button to display the Menu screen. Use cursor-down to select Settings (toolbox icon), then press * in the center of the cursor pad. Use cursor-down to select the second item, then press cursor-right, then *.
SOURCE: LANGUAGE SETTING JAPANESE TO ENGLISH
Hello analyn
There may be a simple fix to this problem.
Find a friend that has a cybershot of the same model as your own. In their camera, open the menu and navigate to the language setting. While you do this count how many times you press the button. Example:
Menu
-camera settings 1
-program 2
-personal settings 3 press ok
personal settings
-storage type 1
-date and time 2
-language 3 press ok
language
-spanish 1
-english 2 press ok
-japanese
Although the language is different, the number of spaces should be the same, so even though you can't read it to change the language, you should be able to count it out. Or if you are lucky you may have a Japanese friend who can read it.
Hope this helps
-Chris
SOURCE: change language from japanese to english
Does this help? "Changing the Language Setting" is located on the first page towards the bottom. It instructions of the symbols you select to reach the language section.
http://www.docs.sony.com/release/DSCW30-W40-W50-W70_rtf.pdf
If this doesn't work could you try using google translate the locate the language section?
http://translate.google.com/#ja|en|
SOURCE: How to switch language on japanese bought sony dsc-wx1 cybershot?
I bought a camera in Japan (Sony Cybershot DSC-WX1) and now it seems that i can't change the language from japanese to english. If i select (can't read it but with the help of the english digital guide i think i have the right menu)change language, there seems to be only one language available. -japanese- How do I solve this?
SOURCE: My Sony DSC-W350 bought from
Changing language settings on digital cameras sometimes can be confusing. We will have to make use of the menu symbols so that we can change the language from Japanese to English. The picture below shows us the navigation buttons that we will use in this process.
1. Press the MENU button
2. Choose .
3. Choose
4. Choose
5. Choose English.
I hope this works for you. Kindly reply for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
TIPS: Is your computer slow? This might help
http://www.fixya.com/support/r8158906-diy_manual_pc_tune_up
(for Windows only)
