SOURCE: u-line CLR 60 B ice maker
U-Line's tech line is 1-800-2547. The compressor, condenser fan and circulation pump operating at the same time?
SOURCE: Ice maker leaks water into Ice bend. When it cycles I can watch it drip water from the ice maker.
not familuar with the brand but sounds like one of 2 issues
if it is overfilling making ice cubes larger than normal, adjust the ice maker fill time if it is possible
icemaker fills and cuts off but water valve seeps water after the fill causing the water overfill
one of the 2
SOURCE: U-Line Echelon Model B12115
Whne you are on site, call 1-800-779-2547 for help. This is U-Line's tech support line,
http://www.u-lineservice.com
SOURCE: Ice maker will not harvest
As crazy as this sounds, turn the temp control a little warmer (counter clockwise). On this model, this control needs to switch to harvest the ice. A warmer setting should fix this issue.
Dean
You can also go to:
SOURCE: Ice Maker not making ice
Here are some basic tips for ice maker troubleshooting...
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
yes I'm having the same, it may or may not start to run through two cycles then stop. When it works it is GREAT, this has been very frustrating.
