Kenmore Elite HE5t Washer Logo
Posted on Aug 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
We are getting an error code of F 35 - Kenmore Elite HE5t Washer
Anonymous
Level 3:
  • Master 4,323 Answers
  • Posted on Aug 06, 2011
Anonymous
Master
Level 3:
Answers
4323
Questions
0
Helped
1232915
Points
12714
Hi
Error code F 35 means ANALOG PRESSURE SENSOR FAILURE. There is any malfunction of the component detected by the Steamer Electronic Board. Please check whether the pressure hose is fixed firmly, and the air trap is not blocked. Make sure the hose is not plugged. If this doesn't resolve the issue then it is a problem with the water level pressure switch operation. There could be a blockage in the air dome or pressure switch hose. The air dome is located on the back of the tub on the left hand side. If the pressure switch hose and the air dome is clear of any blockages, then there is an issue with the water level pressure switch, you would need to replace it. Hope this helps...please post back for further assistance.
Daniel
Porque me sale un "error 35"cuando intento poner mi cuenta de email?
Question edited for clarity.
We only speak English on this North American website.
SBO mailer error code -35
SAP https://answers.sap.com > questions > sbo-mailer-error...
Apr 13, 2009 - Normally, the error 35 occurs when trying to send an e-mail with an. attachment, that cannot be created or accessed via the Attachments. path ...
3 answers · Top answer: Hi,Could you please check if the user is able to create a document inattachments folder ...
SBO Mailer, message fails to be sent
Sep 15, 2009
SBO Mailer
Jan 20, 2006
SBO Mailer Error Log
Apr 3, 2006
More results from answers.sap.com
How do I fix Error code 35 of my brother printer?
This error occurs when a piece of paper or paper clip gets stuck in the printer.
Perform the Troubleshooting Steps to Fix the Brother Printer Error Code 35
  1. From your device cancel all the printing commands that are in the queue.
  2. Open the print head carefully by using the finger holds on both the sides of the machine.
https://www.hprintertechs.com/brother-printer-error-code-35
https://www.youtube.com/watch?v=hy3eymxYp6I
https://www.pcasta.com/printer/fix-brother-printer-error-state/
What does Error code 35 on an induction cooktop mean
A quick web search of "Error code 35 induction cooktop" seems to indicate a possible bad control board in the unit, but you would need to get more specific about the make/model of the unit to know for sure. A Google search should help you find the answer but that seems to be the most common one and mostly relating to Kenmore units.
Feb 18, 2015 • Cooktops
I am having error codes 35 and 75 come up on my induction cooktop
Thank you for your post, friend!
I located that on Electrolux Cooktop error codes "35" and "75" stand for input voltage too low. It could be an issue with your filter board or an issue within the voltages. I would recommend having a professional come out to your cooktop to properly diagnose to avoid any unnecessary part purchases. -Matt
Error code 35
error code 35?
error codes on the minolta print /copy machines usually have a letter followed by four digits e.g. C2035,
please indicate which model and exact error code with a description of the error as seen by the user.
There is a error code 34 35 in my kawasaki z750,2008.let me know the reason for that
Error Code # 34 - Exhaust butterfly valve actuator sensor malfunction, wiring open or short. Error Code # 35 - Immobilizer amplifier malfunction (Equipped Models) These are the exact error codes from the service manual itself. Good luck.
7helpful
4answers
Trouble code 35 chevrolet cruze
please advise what about the code 35 of chevrolet cruze 2010
3helpful
2answers
Error code F 35 and SUD code
Save yourself a lot of time and money and replace the analog pressure switch. This will solve your issues by taking care of both error codes at the same time.
The Appliance Pro
2helpful
3answers
Error code
Problem: The Digital Panel is Reporting Code 34-1, 34-2, 35-1, 35-2 or 36-2 Cause: The copier is having a problem with the fusing unit.
Solution:
  1. This is occasionally a false alarm. Try turning the copier off for about 10 seconds and turning it back on. If the code doesn’t clear, please call 1-800-877-2679 for service.
2helpful
Toshiba e-Studio 35
What error code are you getting? You may just want to get the Intravia's service guide book number 10. If you work on main different makes and models..
Alexander
vince
