Tip & How-To about Washing Machines
A leading problem that will make the washer not drain is a defective lid switch. To check if that is the problem,open the lid and close it slowly,when it is almost closed you should hear a clicking sound,do this a couple times and if you do not hear the click the lid switch is what i would suspect as the problem.
To me a technician with 30 years experience i think the switch is very easy to replace,i believe with some mechinacal ability you too could replace the switch assambly.
If it turns out to be the switch i have attached a youtube video that will show you step by step how to replace it http://youtu.be/MFsvLiuTniU
Good luck,i hope this will help you to fix your washer,
Gene
