Hi if you are making USB Data cable Plant and using Vertical Injection Molding machine then you should take care of some point.
- Proper clean environment: The area of your factory should be clean.
- Proper water line: The water line for mould dies should be proper so that they don't get heated.
- Material: The material for the product should be as per the machine capabilities to attain the maximum output.
- Maintainance: Every machine not only Vertical Injection Molding needs maintenance on a regular basis. If you giving regular maintenance then the machine will keep working through a long time.
- Operator selection: The operator of the machine is the key point of production. So try to work with an experienced operator or under the supervision of an experienced person.
By keeping these points you can increase your production and machine life as well.
https://www.technomachinesindia.in/vertical-injection-molding-machine-15-ton-2-side-operation.php
