Tip & How-To about Crosley CE35111AA Electric Kitchen Range
Appliances Houston
We sell NEW overstock and scratch & dent appliances which come directly from Whirlpool. From ovens to refrigerators, microwaves to washers and dryers, stoves and dishwashers-all your home appliance needs for less than EVERYONE ELSE!
Solocenter.com
Crosley CE35111AA Electric Kitchen Range Logo
dented microwave
You can safely remove the outer shell of a normal microwave oven, by removing the 4, 6 or 8 screws which hold it in place.
It will then be up to you how you repair the dent.
Unless you are very talented, it's actually unlikely that you will be able to remove the dent, although you might be able to make it look a lot better.?
Before you begin any work, make sure you have unplugged the unit from the mains-supply.
Once the cover is off, the potentially dangerous & possibly life-threatening parts are exposed.
DO NOT make any attempt to touch, poke, probe or in any way interfere with the inner-workings.
If you drop a screw, washer or anything else into the inner-workings, taking great car to only touch the outside, physically roll or turn the whole oven over & allow the parts to fall out by themselves.
Always be safe.
Best of luck.
Mar 08, 2018 | Microwave Ovens
Can a dent at the front of a steel oven be fixed?
probably not perfectly, but you can order a new panel
Dec 24, 2014 | Stainless Refrigerators
What turntable motor do I need for a whirlpool MW B10 W microwave?
Refer your inquiry directly to Whirlpool or an appliance parts supplier.
Jun 11, 2014 | Whirlpool GH7155XHS Microwave Oven
Where can I download a manual for Whirlpool AWM321
You could go to whirlpool.com and click ower center and download a maual for your washer,i tried that but it says the model number couldn't be matched
The following is from the whirlpool website and it shows where to find the model#
Please find the type of appliance you are interested in and click on the link to view the likely location of the model number plate on that appliance here is where the model# could be found
Type of Appliance Model Number Plate Location Range Inside oven drawer, on oven rim Wall Oven Inside oven drawer, on rim Cooktop On underside of unit Microwave Inside microwave, on rim Dishwasher Inside dishwasher, on rim Refrigerator Inside refrigerator, on wall Trash Compactor Inside, on rim Food Waste Disposer Attached to the unit Washer Beneath washer lid, on tub rim Dryer Inside dryer door, on rim.
Jul 29, 2011 | Washing Machines
Whirlpool gold GT4175SPS-2 inside door paint is flaking and revealing metal. Is it safe to use?
Scratches, flaking and bare spots are fairly common, but should be addressed as soon as they arise so the corrosion will not spread and arcing does not occur.
Unplug the power cord first.
Take some mild sanding cloth or scotchbright and clean the bare and rusted areas in the microwave. Use appliance touch up paint to re-coat the surface. You can find the touch up at most anywhere that sells appliances, it comes in a plastic bottle similar in appearance to fingernail polish, yes it does have a brush inside.
Let it dry per the instructions on the bottle or 24 hours if not specified.
May 09, 2010 | Microwave Ovens
280 people viewed this tip
Top Crosley Kitchen Ranges Experts
steve johnson
Level 1 Expert
Chris Huff
Chris Huff
karen sharon
karen sharon
Level 1 Expert
Are you a Crosley Kitchen Range Expert? Answer questions, earn points and help others
