Tip & How-To about Whirlpool Washing Machines
Wet cloths or error F04
I could not find anything on the internet above this error, the reason for this.
Machine runs fine and completes the cycle with no error, but with 1 fault, cloths are still wet. just once it showed error F04.
I noticed that:-
1. the drum did not spin fast
2. water was draining out of the outlet pipe but at a slow rate
Fix:-
water pump access at the bottom right of the machine was blocked with coins and a plastic strip, cleaned and all working again.
Did not expect the pump to be the fault as water was coming out the outlet pipe.
Washing Machines Logo
My Maytag will not run a complete cycle. Is there
mgissy
What is your machine model number? Is it a FAV6800A or FAV9800A TL?
If it’s a FAV6800A or FAV9800A TL do you error out in the Spin cycle of the wash cycle with an unbalance error code such as dC or uC? Is the wsh tub banging around during Spin Cycle of the Wash Cycle?
If so see this post Clutch Fix. I have a step by step maintenance/repair process for Clutch Pulley assembly issues related to the above error codes.
Post back if you have questions or concerns………Rich
May 03, 2010 | Maytag Neptune FAV6800AW Top Load Washer
my machine stops at "delay start", yet the cycle is not complete.
PROBABLY NOT USING ((((H E DETERGENT) REASON FOR ERROR CODES,, POUR A SMALL AMOUNT OF COOKING OIL ON A SPOON AND POUR INSIDE SHOULD SOLVE PROBLEM
Nov 29, 2008 | Hoover AAA160 Front Load Washer
308 people viewed this tip
Sal De
Marvin
Marvin
jimorris77
