Tip & How-To about Crafts & Hobbies
How to dye leather
It may sound like a very complicated project, but dying leather actually isn’t that hard once you understand how to work with leather.
It’s important to understand the type of leather you are working with and the effect that you are hoping before.
Read on to find out some very helpful leather dying tips:
1: Find out what kind of leather you are working with. This doesn’t refer to the animal in came from but rather the treatments that the leather went through in the past. Ie has it been dyed? With or without a protective layer? Is it pigmented?
2: Choose your type of dye carefully and get advice from the shop where you buy it. Alcohol based dyes produce a stiffer leather finish whereas water based dyes are softer.
3. Choose a color dye but be aware that once it dries it is never the exact same color as the box. If you have a small sample ( a swatch) available, try it out first.
4. Take off the old dye before you apply any new dye. You can buy a leather deglazing product which takes off old dye.
5. Make sure your leather is wet before you start to dye it. Don’t soak it, just use a cloth to make it damp.
6. Now you can apply your leather dye follow the instructions on the packet.
7. Make sure you let the dye dry for several others. It may need manipulating a few times so that it doesn’t become stiff.
Crafts & Hobbies Logo
2answers
I sew thin leather w/Janome MC4000 using leather needle. Want to try thicker leather but not damage machine. How thick will this machine take?
Be careful sewing thick materials with a domestic machine. Even though a lot of machines are supposedly able to sew thick leather & fabrics, it could damage your machine in the long run. If you value your machine, you might want to find a second machine (used mechanicals, older Singers, etc., probably work better for this purpose) to sew thick fabric. Save your nice primary machine for more conventional uses.
How do I fix the leather seats in my jaguar?
Generally speaking, there is no fix. Leather was once a living material, and over time it dries out. There are some over the counter products to bring back the "life" of the material by replacing the oils lost, much like hand lotion for humans. But once the surface has cracked open, there isn't much you can do for it.
You can check with a local upholstery shop to see if they can fill in the cracks.
How should I properly care for and clean my leather recliner?
Leather can become dusty quite easily. It is important that you vacuum it regularly. I suggest buying some leather cleaner and diluting it in a bucket of warm water. Then use a rag to wash the recliner (make sure that you do not apply too much liquid to the leather surface). To remove the cleanser, use a second rag dipped in plain water and then dry off the surface. You may want to invest in some oil to apply to the leather every once in a while to avoid the leather from cracking.
Aug 09, 2012 • Furniture
double vision on jvc 48" rear projection television
No that is not correct
The problem you describe is a convergence issue which can be quite costly. The alignment alone is very complicated and more importantly time consuming
Top Crafts & Hobbies Experts
xxxxxx xxx
ADMIN Andrew
ADMIN Andrew
Carolyn Rogers
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
