When you register or open QuickBooks, you see one of these error messages:
Could not initialize license properties. Error 3371: QuickBooks could not load the license data. This may be caused by missing or damaged files.
Could not initialize license properties. [Error 3371, Status Code -11118] QuickBooks could not load the license data. This may be caused by missing or damaged files.
Could not initialize license properties. [Error: 3371, Status Code -1] QuickBooks could not load the license data. This may be caused by missing or damaged files.
Important: This issue can occur if your product is hosted by Right Networks and you access QuickBooks with WebConnect and then select to open the file without saving. If you use QuickBooks Enterprise and your product is hosted by Right Networks, you must save the file and then import it.
How to fix it:
Before proceeding, ensure that your copy of Microsoft Windows is up to date. If the latest Windows updates are not installed, the QuickBooks installation can fail or become damaged. To install the latest updates in Windows, click the Windows Start or Logo button, choose All Programs > Windows Update. Once started be sure to install any updates marked critical.
You may need to re-install your software. Have your license number and product number for your version of QuickBooks ready.
Try these steps in the order shown. If the first one fixes the problem, you do not need to do the other steps.
I don't know what type of error you face while installation of QuickBooks but i share some of Intuit common error so choose the right one for you Links for installation errors . if still not able to get and need any technical help follow Intuit Tech Support .
