20 Most Recent Easy HOPAR H-9000 Automatic Fish Food Feeder with Timer for Fish Tank Aquarium Questions & Answers
Where can I buy fish food online?
You can check out http://www.aquariumguys.com/fish-food-fish-feeders.html they got the entire fish food brands and they also deliver the product in two days, I'm ordering from this site regularly.
3/19/2024 5:15:49 AM • Fish • Answered on Mar 19, 2024
2answers
How much does a 20 gallon fish tank weigh with water
1 gallon (gal) = 3.785411784 kilogram (kg). 20 gallons = 75.708 Kg Plus the weight of the empty tank (depending on tank construction, glass or part steel etc.)
12/20/2023 1:25:35 PM • Fish • Answered on Dec 20, 2023
Pump size required for 1/6
11/20/2023 8:31:31 PM • Fish • Answered on Nov 20, 2023
3answers
Can I find a replacement piece of glass for the bottom of my 36 gallon bowed front aqueon aquarium?
Sections of tanks can be replaced BUT you would have to get a specialist to do it as even a tank that size has to take a huge amount of weight on the glass and joints. A 36 gallon tank, when full has over 300lbs, (136kg),of weight on the base. It might be cheaper and easier to replace the whole tank.
9/20/2023 9:24:00 AM • Fish • Answered on Sep 20, 2023
3answers
Hello.. Is this arrangement of blue and red sponges correct? When I switched On, water is spilling out.
Looks like a Pond Filter or a Pool Filter, so I moved you from Office Supplies Category. Google make model manual Or tell me and I can find the information. Click COMMENT under my post.
6/6/2021 6:04:26 PM • Fish • Answered on Jun 06, 2021
How do you install the batteries in a top fin automatic feeder?
This link might help: https://www.google.com/search?q=How+do+you+install+the+batteries+in+a+top+fin+automatic+feeder?&source=lmns&bih=625&biw=1366&hl=en&sa=X&ved=2ahUKEwiIrqOql_PwAhWHJ7cAHWDkBR0Q_AUoAHoECAEQAA
5/28/2021 2:12:49 PM • Fish • Answered on May 28, 2021
Looking for info on how to replace the side protectors and easy clips on a Eheim 2026 / 2028 canister filter
Here is the Manual Karen
Eheim Professionel II 2028 Manuals ' ManualsLib
www.manualslib.com > ... > EHEIM Manuals > Other
... II 2028 Pdf User Manuals. View online or download Eheim Professionel II 2028 Operating Instructions Manual. ... External aquarium filter. Brand: EHEIM ... ..
3/7/2021 2:29:00 AM • Fish • Answered on Mar 07, 2021
Instruction manual for a Topfin aquarium power head pump 50 model number PH=601
Unboxing and Testing of Power Head Recent AA 1200 Submersible Pump. CLICK: https://goo.gl/J4sgjG
11/25/2020 3:07:58 PM • Fish • Answered on Nov 25, 2020
Light unit not working after replacing bulbs
Try another wall connection or your wire connection, as well as making sure nothing is wet around the connections, and ultimately nothing is wrong with the entire lighting system.
1/3/2020 8:22:26 PM • Fish • Answered on Jan 03, 2020
I have started having tiny snails showing up in my aquarium. Where could they be coming from
They come from eggs that were hidden within the aquatic vegetation you placed in the aquarium that your fish use to discharge them away from being viewed or easily reached.
1/3/2020 8:17:11 PM • Fish • Answered on Jan 03, 2020
2answers
Fluval chi aquarium light does not turn off, defective switch how do I repair it?
Much too late to help, I'm sure, but the cheapest fix would likely be to add a simple tap switch.When the tap switch is turned off, it cuts the power off and the light will go out. A tap switch is simply an outlet with a switch fitted. Plug the tap switch into the wall, plug the aquarium light into the tap switch and you're set. They're cheap at places like Home Depot, likely half the price of the replacement switch from Hagen, who makes Fluval. Also a great way to make it easy to turn filters on and off without having to pull the cord from the outlet.
12/26/2019 9:05:37 PM • Fish • Answered on Dec 26, 2019
How to assemble?
"How to assemble? - Fish"??? Umm, you take the body and stick the marked fins on the sides, top, and back at the appropriate slots then install the batteries and drop it in the tank.
12/25/2019 2:07:17 AM • Fish • Answered on Dec 25, 2019
3answers
Is fall to late to transplant house plants to
That would depend on the plant. Some plants can be transplanted at any time.
12/3/2019 6:50:36 AM • Fish • Answered on Dec 03, 2019
They get plants, algae, and bacteria.
Bacteria in fish tank ? Bacteria is normal . breaks down ammonia from fish into nitrate. Nitrate is harmful and requires a water change unless you pump the water through plants google aquaponics. Algae in fish tank ? buy water snails put in tank
10/22/2019 10:11:28 PM • Fish • Answered on Oct 22, 2019
2answers
I need aquarium filter for my 300l tank. Would you help me with the choice?
I think, a sponge filter is for you - simple, cheap and effective. It provides mechanical and biological filtration, once the sponge has grown bacterial colonies. Filters come in a variety of sizes shapes, and pore sizes to adapt them to an almost filtration need. Sponges give excellent results in ponds, saltwater, and freshwater. They can be used as an addition to another filter, such as a canister filter, or as the only source of aquarium filtration - https://great-filter.com/best-sponge-filter/
7/29/2019 10:22:05 AM • Fish • Answered on Jul 29, 2019
Do I require a fishing licence to fish in my riparian right pool?
If you have plan fishing in public water, sure you need to get license. I prefer fisihing in private pond so, i do not need to get such license. Btw, speaking of fishing, guys I bought recently new bass jigs wtress 2700 after reading review on https://fishinggearforbass.com/best-bass-jigs/ about this bass jigs
7/11/2019 12:22:24 PM • Fish • Answered on Jul 11, 2019
3answers
What kind of filter should I buy for my aquarium?
In my opinion, power filters are the best. They are easy to maintain and are also quite economical. The most common style of power filter hangs on the back of your tank. A siphon will pull water from the tank, eliminating any bacteria and returning filtered water back into the aquarium.
6/21/2019 5:15:11 AM • Fish • Answered on Jun 21, 2019
4answers
Seo agency in London ?
Currently looking for an London seo london Agency, due to the fact I at the moment dwell in that place, and have alot of labor inside my portfolio of internet sites.
6/5/2019 4:05:33 AM • Fish • Answered on Jun 05, 2019
How do I remove the circular fluorescent tube in my Phillips TCG700 light fitting
twist a quarter of a turn
4/9/2019 12:00:47 PM • Fish • Answered on Apr 09, 2019
Easy HOPAR H-9000 Automatic Fish Food Feeder with Timer for Fish Tank Aquarium Logo
1 questions posted
Top Easy Fish Experts
Keith
Level 1 Expert
ADMIN Andrew
ADMIN Andrew
Are you an Easy Fish Expert? Answer questions, earn points and help others
View Most Popular
Easy Fish
  • Easy Fish
Most Popular Question
triazicide granules used in green houses
  • Fish
