20 Most Recent
Samsung HL-S6767W DLP TV Questions & Answers
My Samsung 67" has white
I have the same problem on my 42" Samsung. It started as one dot now there are six. The TV repair shop told me they can sometimes fix it by adjsuting the voltages. If not it is the DMD board. I called Samsung on Jan. 6/11. They told me that as of Dec. 31/10 they would no longer repair the sets for free.
9/27/2019 1:57:28 AM •
Samsung...
Answered
on Sep 27, 2019
Samsung DLP HLS6767W chirping???
change the color wheel its worn out the chirping or whirr comes from the color wheel in the light engine u will need a tech to replace it
7/14/2013 9:48:49 PM •
Samsung...
Answered
on Jul 14, 2013
I am having a problem
I would try replacing the entire ballast. Make sure that the lamp switch is good too. 3 blinks usually indicates an open lamp door.
6/16/2011 11:08:05 PM •
Samsung...
Answered
on Jun 16, 2011
When I replaved samsung hls6767w
Most of the time the female end of the connector comes right of a part called the ballast. Ballast's are replacable. Is the aluminum melted? I am not sure where to purchase the ballast. The female connectors is ussally atached to frame with screws or sometimes clips
5/27/2011 5:37:52 AM •
Samsung...
Answered
on May 27, 2011
My HLS6767W turns itself off, no lights, just a
The lamp may be approaching time to replace. If the lamp is just on the
edge of its functional envelope, under certain circumstances, the
ignition circuit will detect the lamp as failed and shut down.
You could always call Samsung and see if you can get this under waranty.
But yes, my guess would be the lamp!
3/7/2011 8:50:03 PM •
Samsung...
Answered
on Mar 07, 2011
Turn it on in a normal state stays on for 30
I suspect either your lamp is at end of life OR as one projector I worked on the heat sink for the DLP chip was totally occluded with dust causing chip to overheat.
1/26/2011 7:40:13 PM •
Samsung...
Answered
on Jan 26, 2011
What is causing my picture to darken on my samsung
Most likely the tv projection lamp life are ending.The tv projection lamp been inside this tv like 1 1/2 or 2 years?Tv been on watches like 4 or 5 hours each day?The tv projection lamp life are ending,require a new tv projection lamp.
1/4/2011 11:54:26 PM •
Samsung...
Answered
on Jan 04, 2011
