20 Most Recent Coleman 10' X 10' Sundome Tent 9160K101 Questions & Answers
2answers
I have cracks on my coleman pop camper rubber roof
Roll with a fibrous roof coating. make sure it has the fibers or else it will not adhere to the cracks or metal.
3/11/2020 11:12:40 AM • Coleman 10' X... • Answered on Mar 11, 2020
2answers
I need new canvas on my coleman newport. Can you
Look up local RV dealers OR sail manufactures
9/10/2019 3:41:47 PM • Coleman 10' X... • Answered on Sep 10, 2019
Have used 1981 Coleman pop-up camper and the
My Coleman has the same problem. I can crank the top up but it will not hold in place.
I just leave the crank handle in place after raising the top and secure the handle to the bumper with a bungee cord. It's jury rigged but it works great.
9/1/2018 6:40:38 AM • Coleman 10' X... • Answered on Sep 01, 2018
I purchased a camp trailer
go to the Coleman web page and down load a user manual for that model or simply talk to a Coleman tech representative to get the info
7/8/2017 9:19:56 AM • Coleman 10' X... • Answered on Jul 08, 2017
I have had two small Coleman 'Frontier PZ' propane
there is something in the jets or the piping to the mantels, you my find spider webing there, if you did no cap the port where the tank goes some small friends might have wanted to go camping with you.
4/4/2017 1:44:03 AM • Coleman 10' X... • Answered on Apr 04, 2017
My heater on my coleman electric fireplace Model
HI,
Sorry for my english, I,m french. I'm from Québec, Canada.
I have the same problem with my fireplace. Same model.
Do you have the manual or the papers who came with the fireplace. My electrician need it. May you scan or fax to me?
Thank you very much.
Jacques Blanchet
Fax: 1-819-762-0130
email: [email protected]
2/7/2017 2:41:11 PM • Coleman 10' X... • Answered on Feb 07, 2017
2answers
How to light coleman lantern
Kerosene lanterns require a little more than just lighting the mantles. Go to Coleman's website and find the directions (for free) for KEROSENE lanterns. The generator on the lantern needs to be preheated with alcohol before it will actually light. Make sure lantern is a Kerosene lantern and not a white gas (Coleman fuel) type, there is a difference even though they look similar.
12/1/2016 3:27:56 AM • Coleman 10' X... • Answered on Dec 01, 2016
Need an instruction booklet for Wild Country Blaxland 64283 Tent
If you go to www.coleman.com Use the product services link for product manuals. You can then choose tents. Or you can use this link:
http://www.coleman.com/coleman/images/pdf/2000000136.PDF
11/11/2016 11:02:43 PM • Coleman 10' X... • Answered on Nov 11, 2016
2answers
Coleman multi maxi bar can
Usual problems are:-
No gas from supply cylinder.
Safety bypass not allowing start up gas flow.
Piezo lighter not sparking.
Another possibility, strange as it mat sound, is the burner being blocked by mud-wasps; difficult to believe, easy to rectify.
11/5/2016 8:00:30 AM • Coleman 10' X... • Answered on Nov 05, 2016
3answers
I have a Coleman model FL 28-R electric fireplace,
There is a fuse located over the heating element in front of the fan. It sits over a small slot above the heating element (probably to cause it to stop working by design). Yes I'm a pessimist. It can be bypassed if it is an emergency by wiring across it. I'm trying to find the replacement fuse now (10amp jet 250v #00575) If you find it please send info to [email protected]. I hope we all get our heaters working, for $250 + dollars you'd expect it to last longer than 1 month.
10/9/2014 6:05:51 PM • Coleman 10' X... • Answered on Oct 09, 2014
How to take apart a model 237 lantern. i removed the nut on top but the handle passes through the top into the sides and i cannot get it off. I don't want to break it
Tough without pictures but this may be a model that has a spring base the lens is on. Try pushing down. If you post a picture I am sure I can help you out.
4/20/2014 10:08:10 PM • Coleman 10' X... • Answered on Apr 20, 2014
0answers
Battery won't charge on 1million candlelight spotlight pml9000
Replace the battery, Lowes sells the sealed lead battery's for $14.95. Check in the section they sell 'EXIT' signs the battery number you will be looking for is #30128 made by Utilitech. Step 1. Unlock the bulb careful not to pull too hard to prevent snapping off the ground wire for the bulb and unplug the 'black' and the 'red' wire from the battery terminals.Step 2. Locate the 2 screws on the side in the grey area use a P1 Phillips screwdriver a P2 will not fit. Step 3. Carefully pry the 2 half's apart dont pull too hard but just enough to allow the battery to slide out.Repeat the process in reverse to install the new battery.
1/10/2014 7:08:08 AM • Coleman 10' X... • Answered on Jan 10, 2014
Where can i get assembly instructions for great outdoor tent
You can get instructions for Great outdoor tents if their not too old from Great Outdoors Hastings
10/24/2013 6:23:59 PM • Coleman 10' X... • Answered on Oct 24, 2013
Coleman 10' X 10' Sundome Tent 9160K101 Logo
381 questions posted
Top Coleman Sport & Outdoor - Others Experts
Kardoc
vince
john h
Are you a Coleman Sport and Outdoor - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Coleman Sport & Outdoor - Others
Most Popular Question
need manual 2000 coleman taos pop up
  • Sport & Outdoor - Others
