20 Most Recent Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Questions & Answers
Craftman lt2000 drive belt diagram
I'm not sure what you're asking for exactly, but you can find a diagram of the Craftsman LT2000 here: https://mowerslab.com/craftsman-lt2000-drive-belt-diagram/
10/15/2022 8:32:27 AM • Craftsman 20 hp... • Answered on Oct 15, 2022
Mtd Yard Bug Riding Mower 500 series It was working fine now won't move in forward gear.
Question edited for full make model (what it is). Question moved from Cars and Trucks. Sounds like one side of the gear selector cable is slack. https://www.google.com/search?q=Craftsman+yard+bug+500%2C+not+moving+forward ..
4/23/2022 12:36:27 AM • Craftsman 20 hp... • Answered on Apr 23, 2022
I need a manual for a Craftsman LTX 1000 year 2001
it takes sae 30 oil & if i can get the model# of the unit i can see if i have a manuel for it thanks wade
12/16/2021 5:43:45 AM • Craftsman 20 hp... • Answered on Dec 16, 2021
When driving on highway car feels like it is running over several bumps....something like riding on the edge of road where you hit grooves to let you know you need to move over. What is that?
Take your car to a tire store and have them check the tires for you. It sounds like your have a broken belt in one of your radial tires.
11/25/2021 3:05:08 AM • Craftsman 20 hp... • Answered on Nov 25, 2021
3answers
Need a manual for a LT1000 craftsman 19 1/2 HP 42 inch mower deck
You can download a free copy at www.managemyhome.com or you can go to www.searspartsdirect.com and buy a copy along with look at the diagram that you need.
7/19/2020 1:00:37 AM • Craftsman 20 hp... • Answered on Jul 19, 2020
2answers
Drive belt diagram craftsman
if you can provide the model number (usually under the seat), I might be able to pull up a diagram.
10/2/2018 10:37:54 PM • Craftsman 20 hp... • Answered on Oct 02, 2018
My craftsman dsl 3500 run fine for a good while
tune up.
2/7/2018 8:05:50 AM • Craftsman 20 hp... • Answered on Feb 07, 2018
2answers
I have a craftsman 20
Make sure belt is installed like drawing.
12/9/2017 9:54:32 PM • Craftsman 20 hp... • Answered on Dec 09, 2017
Craftsman lt2000 drive belt. The
Hopefully this is like your mower Item 56 is your belt maybe it will be of some help. 10036334-00005-svlhhucpg3yfogwt2cgj0zh0-3-0.png
10/29/2017 9:03:52 PM • Craftsman 20 hp... • Answered on Oct 29, 2017
Craftsman Model 917.276641 shuts off after short
Coil is probably overheating
10/13/2017 12:23:39 PM • Craftsman 20 hp... • Answered on Oct 13, 2017
3answers
I have a Sears Craftsman Lawn Tractor, Model
Have you checked the oil in the crankcase, is it full ?
Has engine been sitting along time ?
Have you double checked all the battery conections, all are tight, good ground connection to motor ?
Please let me know.
10/8/2017 10:20:52 PM • Craftsman 20 hp... • Answered on Oct 08, 2017
My riding Craftsman ;awn mower (20 HP) suddenly
is it a twin cylinder? check to see if it blew one of the spark plugs out. look and see if there is any oil around the engine that looks fresh. it may have a broken connecting rod.
8/23/2017 10:35:15 PM • Craftsman 20 hp... • Answered on Aug 23, 2017
Lawnmower sat up for a season would not crank
If it will start when you pour gas then its a fuel problem on some of these they have a screw at the bottom of the carb remove that and see if you have bad fuel. If that does not work then remove the carb and service it may just be a stuck float or something
8/9/2017 2:06:15 AM • Craftsman 20 hp... • Answered on Aug 09, 2017
2answers
Craftsman LT1000 Wont crank over.
This is not always the case but on Briggs and Stratton it may be time to check the valves for adjusting. Take off the cover and check for a gap of .005 . If the exaust valve is loose it will not allow the engine to relieve combustion to start. In other words the engine stays under load of compression and can't turn. In my shop I see this all the time . If all electrical checks out try this next
6/10/2017 12:56:44 AM • Craftsman 20 hp... • Answered on Jun 10, 2017
Craftsman DLT 3000
Maybe the wire to the seat switch came off or broke, or the switch came loose from vibration. Have you checked?
4/22/2017 5:53:44 PM • Craftsman 20 hp... • Answered on Apr 22, 2017
3answers
Craftsman LT 1000 deck belt diagram
my clutch belt will not stay on the pulleys Craftsman 42 in. LT 1000
3/13/2017 2:40:35 AM • Craftsman 20 hp... • Answered on Mar 13, 2017
Craftsman garden tractor wont go up hill
sounds like the drive belts are worn to the point of slipping. need to replace them
2/5/2017 10:17:21 PM • Craftsman 20 hp... • Answered on Feb 05, 2017
2answers
How do I get my mower deck set properly? Any tricks?
check your front tire air pressures
5/22/2016 5:08:44 PM • Craftsman 20 hp... • Answered on May 22, 2016
How much oil does the engine take for an oil change
Briggs & Stratton engines typically take 48 ounces of SAE 30 oil. Kohler engines typically take 64 ounces (2 quarts) of 10w30 oil. Always refer to the dipstick to ensure proper amount is added and do not over fill.
4/25/2016 8:33:08 PM • Craftsman 20 hp... • Answered on Apr 25, 2016
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
863 questions posted
Top Craftsman Garden Experts
john h
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
View Most Popular
Craftsman Garden
  • Craftsman Garden
Most Popular Question
much oil engine oil change
  • Garden
