20 Most Recent Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Questions & Answers
2answers
17 hp craftsman lawn tractor valve adjustment
You watch the videos, they said different. I go with .004 on intake& EXHAUST. Type in adjust valves ( your engine) in Goggle, watch a video.
10/30/2023 6:12:25 PM • Craftsman 17.5... • Answered on Oct 30, 2023
3answers
Carburetor linkage on a 1999 ranch king with a 17
Here are various graphics from the B&S Intek Twin governor. Maybe they're close . . .
10/14/2023 3:39:05 PM • Craftsman 17.5... • Answered on Oct 14, 2023
2answers
Craftsman DLT 3000 lawn tractor. It won't turn over with a new battery.
Question edited for clarity, 'make model (what it is)'. Question moved from Cars and Trucks. Batteries can be new and not be fully charged. Lots of ideas in the link, but test the starter solenoid first. https://www.google.com/search?q=Craftsman+DLT+3000+lawn+tractor.+It+won%27t+turn+over+with+a+new+battery .. This battery tells you how to load test a battery, about connection being clean. Also that new batteries aren't always fully charged. He explains the solenoid function And another good electrical testing video.
8/5/2023 12:24:59 AM • Craftsman 17.5... • Answered on Aug 05, 2023
Craftsman lt 1500 wont start
Poor performance starter motor or low battery.
7/4/2022 6:36:54 AM • Craftsman 17.5... • Answered on Jul 04, 2022
4answers
2015 Craftsman LT400 Garden Tractor pours out billows of white smoke, runs for a while then cuts off. 17hp 42 inch cut.
Question edited for clarity. Question moved Craftsman Model. That is odd, I usually state white smoke is water blue smoke is oil black smoke is rich mixture but it is air cooled.. However, you are not alone. check out the videos. https://www.google.com/search?q=2015+craftsman+lt400+engine+white+smoke ..
6/17/2022 10:19:35 AM • Craftsman 17.5... • Answered on Jun 17, 2022
Countax A2050 Lawn Tractor lurches and belt comes off when I drive forward?
Question edited to add '(what it is)'. Question mover from Cars and Trucks to a Lawn Tractor one. Belts only come off in a few circumstances. Misaligned pulleys. Worn Belt. New belt, wrong size. Tensioner not working properly. Belt not properly tensioned. In your case, I think the clutch snatching is causing the belt tensioner / idler wheel to pull in fiercely and throw the belt. https://www.google.com/search?q=Countax+a2050
Countax A20/50 Operator's Manual - ManualsLib
https://www.manualslib.com > ... > A20/50 View and Download Countax A20/50 operator's manual online. A20/50 lawn mower pdf manual download.
4/21/2022 9:46:43 PM • Craftsman 17.5... • Answered on Apr 21, 2022
2answers
Removal of rear wheel on cox stockman ride on mower
These wheels are usually just held on with a Key way, ALOT OF TIME they offer resistance because they are rusted insode the rim and are needing a mallet to hit them from the inside pretty hard.
Turn it as you can usually a lever on the back side of the mower can be pulled out without the brake on to slip the transmission into nuetral. Turn the tire. I have used a small peice of 2x4 as well because a hammer dont fit well. Good luck I will watch this post and search my Diagrams to see if i have this rider tmrw at work.!
2/16/2022 11:07:39 PM • Craftsman 17.5... • Answered on Feb 16, 2022
Wiring diagram for craftsman lawn tractor model
944.601140 Sure this is right number?
9/7/2021 1:18:00 AM • Craftsman 17.5... • Answered on Sep 07, 2021
Tractor keeps blowing a fuse
Check for a wire that has a bare spot on it rubbing the body of this mower. The vibration the engine makes shakes the wiring so it must have a bare spot somewhere under the seat or towards the engine
8/21/2021 8:34:24 PM • Craftsman 17.5... • Answered on Aug 21, 2021
Craftsman lt1000 stuck in neutral
The rear wheels are keyed to the axle shafts with a sqaure key, if the last owner forgot to replace one of the keys the axle will just turn in the centre of the wheel and not turn it, because the gearbox has a diff it means neither wheel will turn if either side has the square key missing, pull the wheels off and check the key is there.
6/30/2020 11:22:25 PM • Craftsman 17.5... • Answered on Jun 30, 2020
Mower blades won't engage craftsman lt1000
I had a similar problem with my LT1000 after the winter: engine started and ran but the blades wouldn't engage. You need to drop the deck. There are about 7 cotter pins holding it in place. It will help first to lower the deck, then to raise it after releasing the cotter pins. Then you can slide it out to the side. Take a picture of the belt and pulleys running from the crankshaft under the motor and the path around the pulleys. This will be a good chance to sharpen or replace the blades. Check that the pulleys and blade spindles spin well. Take more pictures for reassembly. There are four springs which give resistance while engaging the blades, another that counteracts to release the blades and engage the brakes on the blades, and then a spring on each of the brakes. Check that everything slides well. Disassemble, clean rust and lubricate as necessary. In my case there was rust here and there that needed to be cleaned before the pieces would slide. Spent some time scraping and lubricating - plus running to get a new spring at the hardware store, before getting back into action. As others have pointed out, check the seat spring and the actual cable to the clutch. The hardest part may just be figuring out how to drop the deck. Good luck. This was a hand-me-down mower that hadn't received use in a couple of years.
4/26/2019 9:19:14 PM • Craftsman 17.5... • Answered on Apr 26, 2019
My riding mower workes fine fore about 45 mintes
Im assuming the tractor is a hydrostatic, in this case when the transmission starts to go...thats it, call the company and find a replacment or get another tractor. unfortunately rebuilding them isnt all that worth it
4/12/2019 5:12:27 PM • Craftsman 17.5... • Answered on Apr 12, 2019
Craftsman LT2000 transmission won't engage
Sounds like you either lost a bearing inside the transmission or that something in the linkage system has come loose and shifted. easiest way is to jack the unit up and visually follow the shifting hardware, while having someone trying to engage it with unit shut off and see is you can visually find where the shaft is slipping or failing to move. Hope This Helps Don
3/27/2019 5:14:58 PM • Craftsman 17.5... • Answered on Mar 27, 2019
3answers
Lawn mower dies
Find the fuel air mixture screw and while the mower is running turn so mower almost stops then turn them back till the moter is running smoother.Give it some throtle to see & hear how it is running
9/8/2018 12:19:57 AM • Craftsman 17.5... • Answered on Sep 08, 2018
Replacing the inner spring of attachment lift lever
You should have a roll-pin as a stop for the spring. Use a hammer and drift punch the same size or larger than the roll pin to drive the pin up to the lever arm. Change to a drift punch just a tad smaller than the hole but still covering as much of the pin as you can without the punch getting stuck inside the roll-pin--in which case just use a pair of pliers and twist and pull. Hope it helped
3/30/2018 4:07:29 PM • Craftsman 17.5... • Answered on Mar 30, 2018
Where does the clutch return spring on a YTS 3000 connect from the shift lever?
go to Sears Parts direct.com they will help you may even be able to download as owners manual
3/21/2018 12:05:33 AM • Craftsman 17.5... • Answered on Mar 21, 2018
Lawn tractor shuts down when it gets hot
Sounds like one or more of the spindel bearings is seizing up when they get hot next time it does that feel the spindels if one or more replace it or just replace the bearing much cheaper
1/19/2018 6:56:00 PM • Craftsman 17.5... • Answered on Jan 19, 2018
I have a wizard riding mower, model 13ah66ofo98
couple of things to check 3.Carburetor Adjustment. A carburetor that's incorrectly adjusted is a common cause of poor engine idling that results in hunting and surging. ... Then slowly adjust the screws tighter or looser in turn until the mower runs and idles smoothly. this first..When the blockage moves or clears, the engine may suddenly rev up in response. To fix this type of problem, check the air filter to ensure that it's not clogged with dirt and debris. Check the vented gas cap as well. Both issues can cause reduced or sporadic air flow, and clearing them will fix the problem. 2.Water in the fuel will do it too. sorry i posted them not in the right order.
1/14/2018 3:24:03 PM • Craftsman 17.5... • Answered on Jan 14, 2018
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
2,432 questions posted
Top Craftsman Garden Experts
john h
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
View Most Popular
Craftsman Garden
  • Craftsman Garden
Most Popular Question
countax a2050 lurches belt comes off
  • Garden
