20 Most Recent
Dewalt DC618KA Angled Nailer Kit Questions & Answers
Hi there. My dewalt dc618
Yes, if it is not pushing the safety back far enough. Also check for pieces of nails debris in the slave slide.
Hi the gun wont fire
Had the same problem with mine. Remove the 3 screws on top and remove the lid. on mine the firing pin assembly was jammed. If the roller seems to be holding the pin carriage too tight then you need to prise up the spring mechanism over the carriage. To do this go to the end at the back of the machine and insert a screwdriver between the top carriage and the frame. prise gently and it should pop up. the firing pin should now move freely
How do I replace the belt on Dewalt cordless dc618?
Remove 2 screws on metal front cover.
Remove screws holding handle halves together and carefully separate (Be careful because trigger spring can fly out on you).
This will expose the belt and allow replacement. There is a spring loaded idler pulley so removal & replacing is easy.
How to fit a firing blade
They are a very complicated tool. You can use this link to view the parts diagram but I would highly recommend taking it to an authorized DeWalt servicing dealer. We are one and I hate working on those tools so I can just imagine how hard it would be for someone not experienced in them.
DeWalt DC618KA parts diagram.
When I pull triger i only get a click from under
Usually caused by stuck head valve or stuck driver. Remove the head and lube the headvalve with white grease or silicone paste. Pull the driver and lube the cylinder making sure that the driver does not fit too tightly in the cylinder.
Need a part schematic for model dc618
go to dewaltservicenet.com and on the left side of page type in your model number and it will allow you to download the breakdown you are looking for. Let me know if you need more assistance.
