20 Most Recent Sunpentown 2,800 Watt 6.5HP Power Generator Questions & Answers
In need of a muffler for a 2800 watt easter steel
I have parts for 2800 and 3300 Eastern Steel Generators including a Muffler you can email me if intrested. 12_29_2011_5_46_05_pm.jpg
9/14/2014 5:50:31 PM • Sunpentown 2,800... • Answered on Sep 14, 2014
On off switch on generator not working
If the unit is starting with no wires to/from the switch, then likely the switch is just supposed to ground the spark in order to stop the engine.
1/22/2014 5:22:29 PM • Sunpentown 2,800... • Answered on Jan 22, 2014
The air cleaner fell off and the nuts that hold the air cleaner on also holds the carb. on
If the studs are there to hold it all in place then just buy the correct ( metric probably) nuts for it.
12/15/2013 7:18:58 PM • Sunpentown 2,800... • Answered on Dec 15, 2013
0answers
Need start wheel
There are many generators made in china that use a generic Honda look-a-like motor. If your gen was made in china, good chance that there is an aftermarket starter assembly. Remove the starter and take it to your local small engine repair shop and ask them to try to match it up with another brand. If the starter is missing, take the generator to shop and ask them to look at mounting and starter cup. Good chance there is something out there that will work. If you have the starter assembly, small engine shop may be able to repair. If the starter rewind riveted to fan cover, take the whole fan comer to shop. Good luck
9/12/2011 9:44:12 PM • Sunpentown 2,800... • Answered on Sep 12, 2011
How much gas to oil
Check for a crankcase with oil in it on the motor...if you have oil in the motor already then you do not need to mix it in the gas...
I am very sure that you will find this motor does not need the gas mixed...
Run straight gas... usually it is good to run Prem in small motors..
heatman101
5/21/2011 4:08:26 AM • Sunpentown 2,800... • Answered on May 21, 2011
Where can you find parts for this 2800 generator?
Try this site: www.shopping.com/sunpentown-tg-2800-generator-parts/products
4/14/2011 11:52:50 PM • Sunpentown 2,800... • Answered on Apr 14, 2011
TOOK CARB OFF TO CLEAN
the little spring should go through same holes as the linkage it's purpose is to take the slack out of the rod to keep the engine running smooth a broken spring will cause it too run erratically
1/16/2011 1:05:19 PM • Sunpentown 2,800... • Answered on Jan 16, 2011
When I rotate the gasoline flow valve from closed
try replacing the hose anyway ,and put new clamps on it some times you can't see the cramps and sometimes the clamps go bad.
12/21/2009 4:50:59 PM • Sunpentown 2,800... • Answered on Dec 21, 2009
Nedd owners manual, parts list and warranty info.
you have got a china copy, hard to get bits for.
whats the prob u got with yours
9/19/2009 6:25:01 PM • Sunpentown 2,800... • Answered on Sep 19, 2009
I need to get an outlit for my 1000 watt genorater
tyr ebay
6/14/2009 7:02:50 PM • Sunpentown 2,800... • Answered on Jun 14, 2009
Manual for scorpion sl2800 generator
Yes
4/9/2024 2:32:16 AM • Electrical... • Answered on Apr 09, 2024
2answers
My conlog meter is showing the rfcon error please what do I do
No connecting to your utilty company in South Africa. Just FYI, we are a North American site and my not always have the answer, in this case we do Https://www.facebook.com/ConlogSolutions/posts/im-having-a-rf-con-error-cant-do-anything-on-the-gadget-please-help-on-how-to-re/962048393965724/ Quoting from link above: "Conlog Hi Ola-daniels, Please see below steps to assist with RFCON error : * Press the Back arrow on the keypad - this step is to refresh the UIU ( the device) * Type # 75 # - this is to check the signal strength If it does not go back to the normal display *Type # 80 # - this is to refresh the meter Then lastly you can repair the meter and the UIU by # 36 # The above steps will work better if you are outside the house because the meters uses the radio frequency connection The above error will occur in instances of bad weather conditions or if there is load shedding or power failure If the problem persists after trying the above you may contact the municipality or the service provider."
SOLVED: How do I clear up the rf con error on my meter ...
https://www.fixya.com > ... > The
May 7, 2020 - How do I clear up the rf con error on my meter because I want to ... Https://www.facebook.com/ConlogSolutions/posts/im-having-a-rf-con-error- ... Hi Ola-daniels, Please see below steps to assist with RFCON error : ... shut down the energy alimentation for 2 minute ,but if the defect persist error it show again. SOLVED: Pole meter conlog rf con meter keep on freezing ... Jan. 10, 2017 Meter reading shows rF CON instead of units available - Fixya Jun. 24, 2018 SOLVED: Good day my conlog ip54 elecricity meter showd ... Oct. 6, 2018 SOLVED: Rf con error - Fixya Jun. 20, 2020 More results from www.fixya.com
Please Help With My Conlog Prepaid Meter - Technology ...
https://www.nairaland.com > please-conlog-prepaid-meter
Aug. 6, 2020 - ystar: If the conlog meter is showing rf-Con, it means power supply doesn't reach the meter at all its either Loss of phase from the transformer or a loose contact ... How Do I Load The Activation Token On My Conlog Prepaid ... Mar. 17, 2020 I Need A Technician To Fix This... - Nairaland / General - Nigeria Jul. 22, 2019 I Need Number Codes To Reset Memmcol Prepaid Meter ... Jan. 11, 2019 More results from www.nairaland.com
3/24/2024 3:42:46 AM • Electrical... • Answered on Mar 24, 2024
Wiring 3 lights 3 separate switches
Consult a qualified electrician.
3/23/2024 7:13:23 AM • Electrical... • Answered on Mar 23, 2024
Sunpentown 2,800 Watt 6.5HP Power Generator Logo
15 questions posted
Top Sunpentown Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Sunpentown Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Sunpentown Electrical Supplies
Most Popular Question
off switch generator not working
  • Electrical Supplies
